Most recent update: 2024-05-02
星本機電配件(上海)有限公司は、株式会社ホシモトの上海現地法人であり、配電盤、分電盤、制御盤等産業用ハンドル、蝶番、プレス・切削・鋳造加工品の製造販売メーカーです。
Zinc alloy( Development and production of prototype/Small-scale production / Casting ) |
Company name |
星本機電配件(上海)有限公司 (Hoshimotokidennhaikennshannhai) |
Website URL | https://www.hoshimoto.co.jp/corporate/list.html |
Street address |
Shanghai People's Republic of China
[See map] |
Person in charge | - |
Capital | 4,000,000 $ | Employees | 100 |
Annual sales | Unregister | EMIDAS Member Number | 95703 |
Type of manufacturing | Heavy electric machinery / Industrial machinery / Telecommunication equipment |
Large | Medium | Small |
Designing | Mold designing | Casting die designing |
Designing | Product and part designing | External design |
Designing | Jig and tool designing | General jig designing Mass production jig designing |
Designing | Data creation (3D scan) | Data creation (3D scan) |
Development and production of prototype/Small-scale production | Machining | General-purpose lathe machining Tapping Rolling Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Copper alloy Automatic lathe Bench lathe machining Brass |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining NC vertical lathe |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining NC set press Deburring Coating Bending (hydraulic) Bending (servo) |
Development and production of prototype/Small-scale production | Blank cutting | Shearing |
Development and production of prototype/Small-scale production | Grinding processing | NC plane grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | Brazing Stud welding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Mass production jig manufacturing |
Development and production of prototype/Small-scale production | Casting | die-cast Lost wax Low pressure casting Metal injection molding (MIM) Zinc alloy 500g or less 500g-5kg |
Die manufacturing | Casting die | Designing Manufacturing Die-casting die |
Mass production | Metal press | Drawing Bending Blanking Transfer press (below 80 t) Iron Stainless steel Aluminum Copper Brass Plated steel plate Thickness Thickness Thickness φ0.6mm - φ9.0mm Combined press-joining Transfer press (80 - 200 t) Single press (below 80 t) Single press (80 - 200 t) Single press (200 - 500 t) Progressive press (35 - 80 t) Progressive press (80 - 200 t) |
Mass production | Mechanical processing | Machining NC milling machining NC turning machining Tapping machining Complex turning machining Wire machining Rolling machining Screw cutting machining Electrical discharge machining Iron Stainless Copper alloy Automatic screw machining Casting |
Mass production | Die-casting | 125 t or less 125 - 250 t Zinc |
Mass production | Forging | Header machining Cold forging Iron Others Below 500 g |
Mass production | Casting | Lost-wax Zinc alloy 500 g and below Over 500 g and less than 5 kg Metal injection molding (MIM) |
Mass production | Sheet-metal processing | Pipe bender processing Bender processing (flood control) Bending process |
Surface treatment | Plating/Chemical conversion treatment | Copper (barrel) Zinc (barrel) Copper (rack) Chromium (rack) Zinc (rack) Nickel chromium (rack) Acid pickling Trivalent Chromate (barrel plating) Iron Copper Brass Zinc die-cast Stainless steel Hard chromium (rack) Degreasing Nickel (hoop) |
Surface treatment | Coating | Powder coating Electrodeposition coating Acrylic coating |
Surface treatment | Polishing/Lapping | Electropolishing Buffing Mirror polishing |
Surface treatment | Barrel polishing | Barrel finishing (vibration) Barrel finishing (rotation) |
Assembly/Inspection | Assembly | Construction component assembly |
Assembly/Inspection | Inspection | Metal press Plastic Forging Casting Powder metallurgy Rubber Spring Bolt/Screw/Nut |
Assembly/Inspection | Side job processing | Manual labor |
Parts manufacturing | Machinery part | Connection parts manufacturing Mechanical parts |
Parts manufacturing | Electrical part | Other electrical part manufacturing |
Parts manufacturing | Bolt/Screw/Nut | Screw manufacturing Screw manufacturing |
Parts manufacturing | Other parts | Lock manufacturing |
