Most recent update: 2024-03-12
Company name |
威海科泰国際貿易有限公司 (Ikaikatei) |
Website URL | Http://castingcnc.com |
Street address | Shandong People's Republic of China | Person in charge | - |
Capital | 2,000,000 JPY | Employees | 8 |
Annual sales | Unregister | EMIDAS Member Number | 89090 |
Type of manufacturing | Industrial machinery / Transportation equipment / Machine tools |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Plano miller machining Deep hole drilling Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Aluminum alloy Copper alloy Nickel alloy Machining (resin) Sintered metal Sintered metal Keyway milling Automatic lathe Shaper machining Lathe machining (resin) Casting Honing Urethane Brass |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining Boring milling NC vertical lathe Machining (horizontal) |
Development and production of prototype/Small-scale production | Sheet-metal processing | NC set press Chassis manufacturing Sheet metal protocol manufacturing Angle machining Pipe bending Coating Mirror surface machining 3-roll bending Bending (servo) |
Development and production of prototype/Small-scale production | Grinding processing | NC plane grinding NC cylindrical grinding Plane grinding Jig boring Internal grinding Centerless grinding NC internal grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding Plasma welding Seam welding Brazing High-frequency welding Friction welding |
Development and production of prototype/Small-scale production | Prototype processing | Punching Welding Bending Powder sintering |
Die manufacturing | Powder metallurgy mold | Manufacturing |
Mass production | Metal press | Drawing Bending Blanking Forming Fine blanking Multi forming Shaving Coining Bulge forming die Combined press-joining |
Mass production | Mechanical processing | Machining NC milling machining NC turning machining Tapping machining Electrical discharge machining Iron Stainless Aluminum alloy Copper alloy Titanium alloy Nickel alloy Broaching machining Automatic screw machining Casting |
Surface treatment | Plating/Chemical conversion treatment | Nickel (barrel) Zinc (barrel) Copper (rack) Nickel chromium (rack) Parkerizing (phosphate film) Electroless nickel (barrel) Electroless nickel (rack) Iron Copper Brass Zinc die-cast Aluminum Stainless steel Hot-dip galvanizing (large-size Dacrotizing Nickel (hoop) |
Surface treatment | Heat treatment | Normalizing Annealing Full annealing Stress relief annealing (SR treatment) Quenching Vacuum quenching Solution heat treatment Carburized quenching Salt bath soft nitriding (tufftriding) Nitridation Gas nitrocarburizing |
Assembly/Inspection | Assembly | Precision equipment assembly Industrial machinery assembly |
Parts manufacturing | Machinery part | Valve manufacturing Pressure container manufacturing Shaft and roller manufacturing |
Parts manufacturing | Electric board and electronic part | Electronic parts assembly and wiring |
Product manufacturing | Construction and civil engineering machinery manufacturing | Civil engineering machinery manufacturing Water supply and discharge system manufacturing |
Product manufacturing | Medical equipment manufacturing | Medical equipment manufacturing |
