Most recent update: 2023-03-31
Sign board manufacturing( Parts manufacturing / Other parts ) |
Company name |
株式会社 イハラ (Ihara) |
Website URL | http://www.niji.jp/home/ihara/ |
Street address |
Kagawa Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 60 |
Annual sales | 1,000,000,000 JPY | EMIDAS Member Number | 83667 |
Type of manufacturing | Construction material / Medical equipment / Lighting equipment |
Large | Medium | Small |
Designing | Mold designing | General metal press die |
Designing | Product and part designing | External design |
Designing | Jig and tool designing | General jig designing Welding jig designing Mass production jig designing General-purpose jig designing |
Material | Steel component distribution | Heavy plate Flat steel plate |
Development and production of prototype/Small-scale production | Machining | Tapping Planer machining Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Aluminum alloy |
Development and production of prototype/Small-scale production | Sheet-metal processing | Can manufacturing Kitchen unit manufacturing NC set press Sheet metal protocol manufacturing Bending (over 3.0 m) Angle machining Deburring Coating Mirror surface machining Hair line machining 3-roll bending 3-roll bending (2 m or longer) Bending (hydraulic) Bending (servo) Can manufacturing (over 5 m) |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing Cutting Laser and turret punch press processing Laser processing (longer than 121.2 m) Shearing (longer than 121.2 m) Corner shearing Laser marking Thick plate (over 6 mm) Stainless steel |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Arc welding Stud welding Other bonding methods |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Welding jig manufacturing Mass production jig manufacturing Jig and tool manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Welding Bending Small-size prototype manufacturing |
Die manufacturing | Press die | Manufacturing Plate machining NC data creation Bending die Roll forming die Single press die Below 60 t 60 - 300 t Sash molding die |
Mass production | Metal press | Bending Transfer press (below 80 t) Iron Stainless steel Aluminum Plated steel plate Thickness Thickness Thickness Press robot (below 80 t) Press robot (80 -200 t) Press robot (200 - 500 t) Press robot (over 500 t) |
Surface treatment | Coating | Air-spray coating Powder coating Resin coating Airless spray coating Urethane coating Acrylic coating Lacquer coating Epoxy coating Metal coating Fluorine coating |
Surface treatment | Polishing/Lapping | Brush polishing Buffing Mirror polishing |
Surface treatment | Other surface treatment | Buffing Sound blast Etching (surface treatment) |
Assembly/Inspection | Assembly | Construction component assembly |
Assembly/Inspection | Repair | Construction repair |
Parts manufacturing | Other parts | Sign board manufacturing |
Product manufacturing | Production property | Environmental equipment manufacturing |
Product manufacturing | Construction and civil engineering machinery manufacturing | Construction and civil engineering material manufacturing |
Product manufacturing | Furniture/Interior | Lighting equipment manufacturing |
