Most recent update: 2022-07-28
Machining (vertical)( Development and production of prototype/Small-scale production / NC machining ) |
Machining (horizontal)( Development and production of prototype/Small-scale production / NC machining ) |
Precision sheet metal machining( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Company name |
株式会社 チューキン 本社・和光工場 (Chu-kinnhonnshawakoukoujou) |
Website URL | http://www.chu-kin.co.jp/ |
Street address |
Saitama Japan
[See map] |
Person in charge | - |
Capital | 10,500,000 JPY | Employees | 6 |
Annual sales | Unregister | EMIDAS Member Number | 80810 |
Large | Medium | Small |
Material | Steel component distribution | Stainless steel Shaped stainless steel Stainless steel pipe Hot-rolled steel plate Cold-rolled steel plate Tool steel Spring steel Free-machining steel Other steel plates and straps Shaped steel Flat steel plate Steel (round) bar Wires Railroad track Seamless steel pipe Rectangular steel pipe Drawn steel pipe |
Material | Nonferrous metal distribution | Plate Flat steel plate Steel (round) bar Steel bars and shapes Copper and brass products Titanium Pipe material |
Development and production of prototype/Small-scale production | Machining | Melt cutting General-purpose milling General-purpose lathe machining Tapping Gear hobber Rolling Thread-cutting Profile milling Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel High rigid material Aluminum alloy Copper alloy Magnesium alloy Titanium alloy Nickel alloy Molybdenum alloy Ceramic Machining (resin) Sintered metal Broaching Keyway milling Automatic lathe Bench lathe machining Simultaneous 5-axis machining Casting Handles microfabrication Titanium |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining 5-face/5-axis machining Boring milling NC vertical lathe Combined lathe machining Machining (horizontal) Handles 2.5-dimensional processing Handles 3D processing |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Can manufacturing Precision sheet metal machining Sheet metal protocol manufacturing Angle machining Thin wall (Thickness |
Development and production of prototype/Small-scale production | Blank cutting | YAG laser machining Turret punch press processing Shearing Cutting Laser and turret punch press processing CO2 laser machining Laser marking Thin plate (below 6 mm) Thick plate (over 6 mm) Stainless steel Copper/Aluminum Acrylic Precision cutting |
Development and production of prototype/Small-scale production | Grinding processing | NC plane grinding NC cylindrical grinding Plane grinding Cylindrical grinding Jig boring Cylindrical mirror grinding Internal grinding Centerless grinding Thread grinding Gear grinding NC internal grinding |
Mass production | Metal press | Drawing Bending Blanking |
Mass production | Glass/Silicon | Glass microfabrication |
Mass production | Rubber | Compression molding |
Mass production | Casting | Shell moulding Lost-wax Sand casting |
Assembly/Inspection | Assembly | Precision equipment assembly Industrial machinery assembly |
