Most recent update: 2023-07-21
Machining (vertical)( Development and production of prototype/Small-scale production / NC machining ) |
Company name |
株式会社 オーティエス (O-thiesu) |
Website URL | http://www.k-ots.com |
Street address |
Tokyo Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 24 |
Annual sales | 600,000,000 JPY | EMIDAS Member Number | 75950 |
Type of manufacturing | Industrial machinery / Telecommunication equipment / Electronic parts |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Rolling Thread-cutting Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Aluminum alloy Copper alloy Magnesium alloy Titanium alloy Nickel alloy Molybdenum alloy Machining (resin) Keyway milling Bench lathe machining Milling (resin) Lathe machining (resin) Titanium |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining Handles 2.5-dimensional processing |
Development and production of prototype/Small-scale production | Sheet-metal processing | Deburring Mirror surface machining Hair line machining |
Development and production of prototype/Small-scale production | Grinding processing | Plane grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | Spot welding Plasma welding Brazing Friction welding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Welding jig manufacturing Mass production jig manufacturing Jig and tool manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Plastic protocol machining |
Surface treatment | Plating/Chemical conversion treatment | Nickel (barrel) Copper (barrel) Chromium (barrel) Electroless copper (barrel) Chromium (rack) Alumite (anode oxidation) Nickel chromium (rack) Acid pickling Aldine treatment (aluminum chromate) Electroless nickel (barrel) Electroless copper (rack) Electroless nickel (rack) Iron Copper Aluminum Stainless steel Hard chromium (rack) Degreasing Colored alumite Hard alumite |
Surface treatment | Heat treatment | Annealing |
Surface treatment | Other surface treatment | Buffing Sound blast Glass beads blast |
Parts manufacturing | Machinery part | Gear manufacturing Vacuum components manufacturing Optical parts manufacturing Shaft and roller manufacturing |
Parts manufacturing | Electrical part | Other electrical part manufacturing |
