Most recent update: 2023-12-07
Thickness: below 0.2 mm( Mass production / Metal press ) |
Company name |
有限会社 エーワン (E-wann) |
Website URL | http://www.a-one402.co.jp |
Street address |
Nagano Japan
[See map] |
Person in charge | - |
Capital | 3,000,000 JPY | Employees | 8 |
Annual sales | Unregister | EMIDAS Member Number | 66408 |
Type of manufacturing | Machine tools / Office automation equipment / Medical equipment |
Large | Medium | Small |
Material | Specialized material distribution | Phosphor bronze Nickel chromium alloy |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Thread-cutting Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Titanium alloy Shaper machining |
Development and production of prototype/Small-scale production | NC machining | NC milling |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining Micro hole machining Electric discharge machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Can manufacturing Air-conditioning equipment manufacturing Precision sheet metal machining Chassis manufacturing Sheet metal protocol manufacturing Bending (over 3.0 m) Angle machining Pipe bending Deburring Coating Mirror surface machining Hair line machining 3-roll bending Bending (hydraulic) Thin wall (Thickness |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing Cutting Laser and turret punch press processing Laser processing (longer than 121.2 m) Shearing (longer than 121.2 m) Corner shearing CO2 laser machining Microfabrication (laser machining ) Nitrogen cutting Thin plate (below 6 mm) Thick plate (over 6 mm) |
Development and production of prototype/Small-scale production | Grinding processing | Plane grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Plasma welding Arc welding Brazing Stud welding Capacitator spot welding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Welding jig manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Punching Welding Bending Small-size prototype manufacturing Chassis prototype manufacturing |
Mass production | Metal press | Drawing Bending Blanking Iron Stainless steel Aluminum Copper Brass Phosphor bronze Titanium Plated steel plate Stainless steel material for spring Nickel Thickness Thickness φ0.6mm - φ9.0mm |
Surface treatment | Plating/Chemical conversion treatment | Chromate (general) Acid pickling Black oxide finish Colored alumite |
Surface treatment | Coating | Air-spray coating Resin coating Melamine coating Acrylic coating Lacquer coating Epoxy coating Heat-resistant coating Metal coating |
Assembly/Inspection | Assembly | Industrial machinery assembly |
Assembly/Inspection | Repair | Office equipment repair Industrial machinery repair |
Parts manufacturing | Machinery part | Gear manufacturing |
Parts manufacturing | Spring | Thin leaf spring Leaf spring Stainless steel |
Product manufacturing | Production property | Machine tool manufacturing |
Product manufacturing | Medical equipment manufacturing | Medical equipment manufacturing |
Product manufacturing | Household commodity | Office equipment manufacturing |
Product manufacturing | Food industry machinery manufacturing | Food manufacturing |
