Most recent update: 2023-10-06
Multi forming( Mass production / Metal press ) |
Progressive press (80 - 200 t)( Mass production / Metal press ) |
Leaf spring( Parts manufacturing / Spring ) |
Company name |
宮川バネ工業 株式会社 (Miyagawabanekougyou) |
Website URL | http://www.m-b-k.co.jp/ |
Street address |
Shiga Japan
[See map] |
Person in charge | - |
Capital | 40,000,000 JPY | Employees | 40 |
Annual sales | 500,000,000 JPY | EMIDAS Member Number | 63046 |
Type of manufacturing | Home electrical appliances / Transportation equipment / Lighting equipment |
Large | Medium | Small |
Designing | Mold designing | Injection molding die Progressive die designing (light electrical) Progressive die designing (auto) General metal press die |
Designing | Jig and tool designing | General jig designing Mass production jig designing |
Development and production of prototype/Small-scale production | Machining | Machining/Handles small-scale production (order from 1 piece) |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Mass production jig manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Punching Welding Bending Small-size prototype manufacturing |
Die manufacturing | Press die | Designing Manufacturing Part processing Plate machining NC data creation Bending die Blanking die Forming die Multi forming die Shaving die Progressive die Single press die Below 60 t 60 - 300 t Compound die |
Die manufacturing | Plastic mold | Injection molding die |
Die manufacturing | Rubber mold | Designing Rubber mold part processing Part processing Packing-related products Home electrical appliances Light electrical/earthing rubber |
Die manufacturing | Spring mold | Designing Manufacturing Spring die part processing Wire spring die Leaf spring die |
Mass production | Metal press | Drawing Bending Blanking Multi forming Shaving Iron Stainless steel Aluminum Copper Brass Phosphor bronze Plated steel plate Stainless steel material for spring Thickness Thickness Diameter φ0.6mm - φ9.0mm Single press (below 80 t) Progressive press (35 - 80 t) Progressive press (80 - 200 t) |
Mass production | Plastic | Injection molding |
Mass production | Rubber | Rubber product prototype manufacturing Silicon rubber Packing-related products Home electrical appliances Light electrical/earthing rubber |
Surface treatment | Heat treatment | Annealing Austempering |
Parts manufacturing | Spring | Thin leaf spring Terminal spring Compression coil spring Tensil coil spring Torsion spring Double torsion spring Leaf spring Shaped spring Battery spring Conical spring Formed wire spring Spring washer Torsion spring Carbon steel Piano wire (carbon wire) Stainless steel Copper alloy Diameter Diameter |
