Most recent update: 2023-04-11
FRP (fiber reinforced plastic)( Mass production / Plastic ) |
GFRP (glass fiber reinforced plastic)( Mass production / Plastic ) |
General jig designing( Designing / Jig and tool designing ) |
Company name |
株式会社 三協製作所 本社 (Sannkyouseisakusho honnsha) |
Website URL | http://www.sankyo-ss.co.jp/ |
Street address |
Kanagawa Japan
[See map] |
Person in charge | - |
Capital | 41,500,000 JPY | Employees | 51 |
Annual sales | 1,200,000,000 JPY | EMIDAS Member Number | 60068 |
Type of manufacturing | Machine tools / Measuring machinery / Industrial machinery |
Large | Medium | Small |
Designing | Jig and tool designing | General jig designing |
Designing | Test | Specimen processing Destructive test Nondestructive test Chemical analysis Investigative research |
Designing | Industrial equipment designing | Industrial machinery designing |
Designing | Simulation | Thermal analysis |
Material | Plastic material distribution | FRP (fiber reinforced plastic) GFRP (glass fiber reinforced plastic) |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Machining/Handles small-scale production (order from 1 piece) Aluminum alloy Copper alloy Machining (resin) |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining |
Development and production of prototype/Small-scale production | Grinding processing | Plane grinding Form grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | TIG welding (argon welding) Arc welding Brazing Plastic bonding |
Development and production of prototype/Small-scale production | Prototype processing | Plastic protocol machining Welding Vacuum injection molding |
Mass production | Mechanical processing | Machining NC milling machining NC turning machining Tapping machining Aluminum alloy Turning machining(plastic) Urethane |
Mass production | Plastic | PVC (polyvinyl chloride) General-purpose material PMMA (polymethyl methacrylate) PBT (polybutylene terephthalate) PPS (polyphenylene sulfide) PEEK (polyetheretherketone) Thermoset resin FRP (fiber reinforced plastic) GFRP (glass fiber reinforced plastic) Urethane resin Below 60 t PES (polyethersulfone) CFRP (carbon fiber reinforced plastic) auto-clave) |
Surface treatment | Coating | Air-spray coating Resin coating Wood coating Aqueous coating Melamine coating Urethane coating Acrylic coating Lacquer coating Epoxy coating EMI shielding coating |
Surface treatment | Printing and others | NC engraving Silk screen printing |
Surface treatment | Other surface treatment | Buffing Shot blast Sound blast Glass beads blast |
Assembly/Inspection | Assembly | Industrial machinery assembly |
Assembly/Inspection | Inspection | Plastic |
Parts manufacturing | Machinery part | Shaft and roller manufacturing pipe manufacturing |
Parts manufacturing | Other parts | Model manufacturing |
