Most recent update: 2017-09-27
Thin wall (Thickness: 0.5 or less)/small-size sheet metal machining( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Company name |
有限会社 こだま製作所 精密板金部門 (Kodamaseisakusho) |
Website URL | http://www.kodama-tec.com?utm_source=nc-network&utm_medium=page |
Street address |
Osaka Japan
[See map] |
Person in charge | - |
Capital | Unregister | Employees | 8 |
Annual sales | Unregister | EMIDAS Member Number | 51968 |
Type of manufacturing | Telecommunication equipment / Office automation equipment / Home electrical appliances |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | Spinning Iron Stainless steel Handles microfabrication |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Precision sheet metal machining Sheet metal protocol manufacturing 3-roll bending Bending (servo) Thin wall (Thickness |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing CO2 laser machining Etching Thin plate (below 6 mm) Stainless steel Copper/Aluminum |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Seam welding Arc welding Brazing Stud welding Capacitator spot welding Other bonding methods |
Development and production of prototype/Small-scale production | Jig manufacturing | Welding jig manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Welding Bending Small-size prototype manufacturing |
Parts manufacturing | Electrical part | Harness processing Connector manufacturing Other electrical part manufacturing |
Parts manufacturing | Spring | Thin leaf spring Terminal spring Tensil coil spring Leaf spring Battery spring Formed wire spring Spring washer Stainless steel Copper alloy |
