Most recent update: 2021-09-23
Combined lathe machining( Development and production of prototype/Small-scale production / NC machining ) |
Company name |
株式会社マルトク (Marutoku) |
Website URL | http://www.kk-marutoku.co.jp/ |
Street address |
Osaka Japan
[See map] |
Person in charge | - |
Capital | 32,000,000 JPY | Employees | 9 |
Annual sales | Unregister | EMIDAS Member Number | 33448 |
Type of manufacturing | Medical equipment / Industrial machinery / Electronic parts |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Deep hole drilling Gear hobber Rolling Thread-cutting Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel High rigid material Aluminum alloy Copper alloy Titanium alloy Machining (resin) Broaching Keyway milling Automatic lathe Bench lathe machining Milling (resin) Lathe machining (resin) Titanium |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining 5-face/5-axis machining Combined lathe machining Machining (horizontal) |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining NC set press Precision sheet metal machining Sheet metal protocol manufacturing Bending (over 3.0 m) Pipe bending Bending (hydraulic) 3D pipe machining Thin wall (Thickness |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing Laser and turret punch press processing Laser processing (longer than 121.2 m) CO2 laser machining Microfabrication (laser machining ) Nitrogen cutting |
Development and production of prototype/Small-scale production | Grinding processing | NC plane grinding NC cylindrical grinding Plane grinding Cylindrical grinding Internal grinding Centerless grinding Thread grinding Gear grinding NC internal grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding TIG welding (argon welding) |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Plastic protocol machining Welding Small-size prototype manufacturing |
Assembly/Inspection | Assembly | Precision equipment assembly Construction component assembly Industrial machinery assembly |
Parts manufacturing | Machinery part | Gear manufacturing Connection parts manufacturing Optical parts manufacturing Shaft and roller manufacturing |
Parts manufacturing | Spring | Leaf spring Formed wire spring |
Product manufacturing | Others | Welfare equipment manufacturing |
