We handle all kinds of special metals that are difficult to obtain in Thailand! BeCu50, ABB2, BSBM, Titanium, Tungsten, Copper tongue, Molybdenum, Hastelloy, Inconel, Stellite, etc.
Copper and brass products( Material / Nonferrous metal distribution ) |
Molybdenum alloy( Material / Specialized material distribution ) |
Stainless steel( Material / Steel component distribution ) |
Machining/Handles small-scale production (order from 1 piece)( Development and production of prototype/Small-scale production / Machining ) |
Can manufacturing( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Jig and tool manufacturing( Development and production of prototype/Small-scale production / Jig manufacturing ) |
Engineering plastic( Mass production / Plastic ) |
Company name | TOKYO METAL CREATE CO., LTD. | Website URL | http://tmec-world.com/ |
Street address |
Klongtan-nua, Wattana, Bangkok Kingdom of Thailand
[See map] |
Person in charge | Maeda (Mr.) |
Telephone number | +66-66-2-381-9141 | Fax number | +66-66-2-318-9143 |
Capital | 4,000,000 THB | Employees | 9 |
Annual sales | Unregister | EMIDAS Member Number | 98615 |
Main 3 products |
PR message
We accept small quantity, high variety, parts processing from one piece, etc.!
(1) Special metals (round bars, plates, wires, pipes) that are difficult to obtain in Thailand
1. Copper, copper alloy, aluminum
2. Rare metals (tungsten, copper tungsten, silver tungsten, molybdenum, tantalum, titanium)
3. 3. stainless
② Precision processed products from 1 piece
1. 1. Electrodes of copper, copper alloys and rare metals
2. Metal and plastic machine parts
3. Sheet metal, welded parts
4. Jigs, molds
③ Special tool from 1 piece
1. 1. Special end mills and drills
2. Special cutting blades, cutters, blades
3. All of them re-polished
4. Deburring brush
Most recent update:2023-07-07
Large | Medium | Small |
Designing | Mold designing | Forging die designing |
Designing | Product and part designing | Office equipment designing Wooden product designing Pressure container designing |
Designing | Jig and tool designing | General jig designing Welding jig designing Mass production jig designing Automatic tool designing General-purpose jig designing |
Designing | Test | Specimen processing Destructive test Nondestructive test Chemical analysis Investigative research |
Material | Steel component distribution | Heavy plate Stainless steel Shaped stainless steel Stainless steel spring Perforated metal Expanded metal Stainless steel pipe Tool steel Free-machining steel Other steel plates and straps Shaped steel Flat steel plate Steel (round) bar Wires Railroad track Other shaped steel bars Seamless steel pipe Galvanized steel sheet Other steel pipes |
Material | Specialized material distribution | 42 alloy Kovar Phosphor bronze Clad steel Molybdenum alloy Tantalum Nickel chromium alloy Tin/Zinc based alloy Ceramic material rolling |
Material | Nonferrous metal distribution | Plate Flat steel plate Steel (round) bar Steel bars and shapes Copper and brass products Titanium Nickel Pipe material Magnesium Coils Others rolling Aluminum extrusions |
Material | Plastic material distribution | PVC (polyvinyl chloride) ABS resin PP (polypropylene) PE (polyethylene) PS (polystyrene) PMMA (polymethyl methacrylate) PA (nylon/polyamide) PC (polycarbonate) PET (polyethylene terephthalate) PPE (polyphenyl ether) POM (polyoxymethylene) PBT (polybutylene terephthalate) PPS (polyphenylene sulfide) PI (polyimide) PEEK (polyetheretherketone) LCP (liquid crystal polymer) Fluororesin PF (phenol-formaldehyde) FRP (fiber reinforced plastic) GFRP (glass fiber reinforced plastic) Urethane resin PU (polyurethane) Acetone Butylene Elastomer EP (epoxy) PES (polyethersulfone) PEI (polyetherimide) PSF (polysulfone) |
Development and production of prototype/Small-scale production | Machining | Melt cutting General-purpose milling General-purpose lathe machining Tapping Planer machining Plano miller machining Deep hole drilling Gear hobber Rolling Thread-cutting Profile milling Straightening Tube drawing Spinning Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel High rigid material Aluminum alloy Copper alloy Magnesium alloy Titanium alloy Nickel alloy Molybdenum alloy Ceramic Machining (resin) Sintered metal Sintered metal Broaching Keyway milling Automatic lathe Bench lathe machining Shaper machining Router machining Simultaneous 5-axis machining Milling (resin) Air chuck equipment Lathe machining (resin) Casting Handles microfabrication Handles microfabrication Honing Titanium pipe manufacturing Urethane Sponge Brass Diamond |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) Additional-axis machining NC milling NC lathe machining 5-face/5-axis machining Five-face machining Boring milling NC facing NC vertical lathe Combined lathe machining Machining (horizontal) Handles 2.5-dimensional processing Handles 3D processing |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining Micro hole machining Electric discharge machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Can manufacturing Air-conditioning equipment manufacturing Kitchen unit manufacturing NC set press Precision sheet metal machining Chassis manufacturing Sheet metal protocol manufacturing Bending (over 3.0 m) Angle machining Pipe bending Deburring Coating Mirror surface machining Hair line machining 3-roll bending 3-roll bending (2 m or longer) Bending (hydraulic) Bending (servo) 3D pipe machining Swaging Can manufacturing (over 5 m) Thin wall (Thickness |
Development and production of prototype/Small-scale production | Blank cutting | YAG laser machining Turret punch press processing Shearing Cutting Laser and turret punch press processing Electron beam machining Laser processing (longer than 121.2 m) Shearing (longer than 121.2 m) Water jet cutter machining Corner shearing CO2 laser machining Excimer laser processing UV laser machining Laser marking Dry etching (routing) Etching Microfabrication (laser machining ) Metal mask manufacturing Nitrogen cutting Thin plate (below 6 mm) Thick plate (over 6 mm) Stainless steel Copper/Aluminum Glass laser machining Ceramic Acrylic PI (polyimide) Other resins Precision cutting 3D laser machining Fiber laser processing |
Development and production of prototype/Small-scale production | Grinding processing | NC plane grinding NC cylindrical grinding Plane grinding Form grinding Cylindrical grinding Profile grinding Jig boring Jig grinding Cylindrical mirror grinding Internal grinding Centerless grinding Thread grinding Gear grinding NC internal grinding Magnetic Abrasive Rotary grinding Double-sided grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Plasma welding Seam welding Arc welding Robot welding Brazing Brazing Plastic bonding Stud welding Submerged arc welding High-frequency welding Friction welding Capacitator spot welding Ultrasonic welding Other bonding methods YAG laser machining Impulse welding Hot plate welding Non-contact hot plate welding High-frequency welding Vibration welding Semiconductor laser welding Infrared welding Fiber welding Projection welding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Welding jig manufacturing Mass production jig manufacturing Jig and tool manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Plastic protocol machining Photoforming Punching Welding Bending Small-size prototype manufacturing Chassis prototype manufacturing Vacuum injection molding Fused Deposition Molding (FDM) Powder sintering Sheet lamination Molten resin method Model manufacturing Porous plastic prototype Plaster casting prototype Aluminum die-casting Prototype/Small-lot molding Small-lot/Injection molding Simplified/Molding prototype mold |
Development and production of prototype/Small-scale production | Blank cutting | Laser marking YAG laser processing Turret punch punching Shirring Cutting process Laser and turret punch punching Electron beam processing Laser processing (over 1.2m) Shirring (more than 1.2m) Water jet processing Connor Shah CO2 laser processing Excimer laser processing Fiber laser processing UV laser machining Dry etching (outer shape processing) Etching Microfabrication (laser) Metal mask manufacturing Clean cut Thin plate 6 mm or less Thick plate 6 mm or more stainless Copper / aluminum Glass laser machining ceramic acrylic Polyimide Other resins Precision cutting 3D laser |
Die manufacturing | Press die | Bending die |
Die manufacturing | Glass mold | Spherical lens molding die Aspherical lens molding die |
Die manufacturing | Rubber mold | Designing Rubber mold part processing Part processing 3D modeling Compression molding die Transfer molding die Blanking die and other auto parts Packing-related products binoculars and optical products Home electrical appliances Mobile phones Light electrical/earthing rubber Medical Sundries and shoes |
Die manufacturing | Forging die | Forging die part processing Cold forging die |
Die manufacturing | Casting die | Die-casting part processing Die-casting die Shell moulding die |
Die manufacturing | Cutting dies | Thomson punch Cutting blade cutting die Corrosion blade cutting die |
Mass production | Metal press | Drawing Bending Blanking Forming Fine blanking Multi forming Roll forming Shaving Coining Transfer press (below 80 t) Iron Stainless steel Aluminum Copper Brass Phosphor bronze Titanium Plated steel plate Stainless steel material for spring Nickel Thickness Thickness Thickness Thickness Diameter φ0.6mm - φ9.0mm Diameter Bulge forming die Combined press-joining Hydraulic counter pressure press Warm forming press Corson alloy Beryllium copper Transfer press (80 - 200 t) Transfer press (200 - 500 t) Transfer press (over 500 t) Press robot (below 80 t) Press robot (80 -200 t) Press robot (200 - 500 t) Press robot (over 500 t) Single press (below 80 t) Single press (80 - 200 t) Single press (200 - 500 t) Single press (500 t and over) Progressive press (35 - 80 t) Progressive press (200 - 500 t) Progressive press (over 500 t) |
Mass production | Mechanical processing | Machining NC milling machining NC turning machining Tapping machining Five-face/axes machining Complex turning machining Wire machining Gear cutting machining Rolling machining Screw cutting machining Micro-hole machining Electrical discharge machining Spinning Stainless Cemented carbide Aluminum alloy Copper alloy Magnesium alloy Titanium alloy Nickel alloy Molybdenum alloy Ceramic Sintered metal Broaching machining Automatic screw machining Air chuck equipment Turning machining(plastic) Casting Honing machining Titanium Fine particle material accepted Urethane Sponge Diamond Seamless Ultra-thin High precision Clad High strength |
Mass production | Plastic | Blow molding Vacuum molding Extrusion molding Insert molding Outsert molding Expansion molding Plastic magnet molding Rotational/Slash/Dip molding Thixo-molding Film-lamination Air pressure molding PVC (polyvinyl chloride) General-purpose material PMMA (polymethyl methacrylate) Engineering plastic PBT (polybutylene terephthalate) PPS (polyphenylene sulfide) PI (polyimide) PEEK (polyetheretherketone) LCP (liquid crystal polymer) Fluororesin Thermoset resin FRP (fiber reinforced plastic) GFRP (glass fiber reinforced plastic) Urethane resin PU (polyurethane) Elastomer Below 60 t 60 - 300 t 000 t Injection molding PES (polyethersulfone) EP (epoxy) Porous plastic molding 000 t Handles small-scale production Thin wall molding Dual molding Metal injection molding (MIM) Pipe extrusion molding Tube extrusion molding Special shape extrusion molding Film (calender) molding Inflation molding Owns dies of commercially availalable size Biodegradable plastic CFRP (carbon fiber reinforced plastic) auto-clave) SMC) Gas injection Ceramic injection (CIM) direct pressurej Sheet / film processing |
Mass production | Glass/Silicon | Other glass manufacturing Glass craft manufacturing Toughened glass manufacturing Glass mirror polishing Spherical lens Optical thin film products Aspherical lens Optical fiber Specialized filter Glass substrate Auto glass parts manufacturing Laboratory glass manufacturing Slicing/Dicing Ultrasonic machining Microblast Glass microfabrication Glass welding Lens hand polishing |
Mass production | Rubber | Rubber product prototype manufacturing Compression molding Transfer molding Blanking Silicon rubber Urethane rubber Butyl rubber NBR SBR CR EPT Fluoro-rubber Acrylic rubber and other auto parts Packing-related products binoculars and optical products Home electrical appliances Mobile phones Light electrical/earthing rubber Medical Sundries and shoes Press stamping Super-size machining Extrusion molding CSM CHR(hydrin) Weather-ability Weight saving Thermostability Electric property Chemical proof Machine tools/Equipments Manufacturers Architecture Injection molding Vulcanization adhesion |
Mass production | Die-casting | 125 t or less 125 - 250 t 000 t 000 t Aluminum Zinc Magnesium alloy |
Mass production | Forging | Header machining Hot forging Cold forging Press forging Drop hammer Forging roll Upsetter forging Iron Aluminum Brass Others Below 500 g 500 g - 5 kg Over 5 kg Warm forging Ring forging Free forging Pressure forging Corson alloy High-strength brass |
Mass production | Grinding processing | NC plane grinding NC cylindrical grinding Plane grinding Form grinding Cylindrical grinding Profile grinding Jig grinding Cylindrical mirror grinding Internal grinding Centerless grinding Thread grinding Gear grinding NC internal grinding Magnetic Abrasive Rotary grinding Double-sided grinding |
Mass production | Sheet-metal processing | Pipe processing Can-making Air conditioning equipment manufacturing Kitchen equipment manufacturing NC set press Precision sheet metal processing Housing manufacturing Sheet metal prototype manufacturing Bender processing (over 3.0m) Angle processing Pipe bender processing Deburring process Painting process Mirror surface material processing Hairline processing 3-roll machine 3-roll machine (6m or more) Bender processing (flood control) Bender processing (servo) 3D pipe processing Swaging process Can making (more than 5m) Thin (t0.5 or less) / Small sheet metal processing Bending process |
Mass production | Blank cutting | Laser marking YAG laser processing Turret punch punching Shirring Cutting process Laser and turret punch punching Electron beam processing Laser processing (over 1.2m) Shirring (more than 1.2m) Water jet processing Connor Shah CO2 laser processing Excimer laser processing Fiber laser processing UV laser machining Dry etching (outer shape processing) Etching Microfabrication (laser) Metal mask manufacturing Clean cut Thin plate 6 mm or less Thick plate 6 mm or more stainless Copper / aluminum Glass laser machining ceramic acrylic Polyimide Other resins Precision cutting 3D laser |
Mass production | Welding / welding | Projection welding CO2 welding Fiber welding Spot welding TIG welding (argon welding) Plasma welding Seam welding Arc welding Robot welding Blaze welding fixing with wax Plastic adhesive Stud welding Submerged arc welding High frequency welder processing Friction welding Condenser spot welding Ultrasonic welding YAG laser processing Impulse welding Hot plate welding Non-contact hot plate welding High frequency welding Vibration welding Semiconductor laser welding Infrared welding Other adhesion |
Surface treatment | Plating/Chemical conversion treatment | Nickel (barrel) Tin (barrel) Solder (barrel) Copper (barrel) Chromium (barrel) Black chromium (barrel) Zinc (barrel) Chromate (general) Rhodium Electroless copper (barrel) Nickel (rack) Tin (rack) Copper (rack) Gold/Silver plating Chromium (rack) Black chromium (rack) Zinc (rack) Alumite (anode oxidation) Nickel chromium (rack) Acid pickling Aldine treatment (aluminum chromate) Parkerizing (phosphate film) Electroless nickel (barrel) Electroless copper (rack) Electroless nickel (rack) Electrocasting Chemical conversion coating Tin-zinc alloy plating (rack) Baking (hydrogen embrittling) Trivalent Chromate (barrel plating) Iron Copper Brass Zinc die-cast Aluminum Stainless steel Plastic Hard chromium (rack) Titanium Magnesium Degreasing Black oxide finish Colored alumite Hard alumite Hot-dip galvanizing (small-size Hot-dip galvanizing (mid-size Hot-dip galvanizing (large-size Dacrotizing Hot-dip aluminum plating Unichromate (white) Black chromate (black/green) Colored chromate (multi-color) Nickel (hoop) solder(Hoop) Gold(Hoop) Electroless nickel (large) Black nickel Hard chrome (barrel) Hard chrome (large) Tin (hoop) Hard alumite (large) |
Surface treatment | Cleaning | Hydrocarbon cleaning 5-layer fully automatic washing twin Trichlene cleaning Ultrasonic cleaning |
Surface treatment | Coating | Air-spray coating Powder coating Resin coating Wood coating Electrodeposition coating Electrostatic coating Flock coating Aqueous coating UV resistant coating Airless spray coating Melamine coating Urethane coating Acrylic coating Lacquer coating Ceramic coating Epoxy coating EMI shielding coating Electrical insulating Heat insulation coating Heat-resistant coating Metal coating Transfer printing Fluorine coating |
Surface treatment | Polishing/Lapping | Electropolishing Chemical polishing Tool polishing Blade polishing Brush polishing Buffing Mirror polishing |
Surface treatment | Printing and others | NC engraving Engraving Printing Silk screen printing Offset printing Silk (handles curved surface) Pad printing Hot stamping (gold embossing) Gravure printing Laser engraving Direct printing |
Surface treatment | Lap polishing | Lap polishing Lap mirror polishing Single-face lapping and polishing |
Surface treatment | Heat treatment | Normalizing Vacuum normalizing Annealing Full annealing Stress relief annealing (SR treatment) Straightening annealing Vacuum annealing Quenching Air quenching Salt bath quenching Vacuum quenching Austempering High frequency quenching Flame quenching Solution heat treatment Sub-zero treatment Carburized quenching Nitridation Gas nitrocarburizing |
Surface treatment | Barrel polishing | Barrel finishing (vibration) Barrel finishing (rotation) Barrel finishing (centrifugal) |
Surface treatment | Other surface treatment | Vacuum deposition Other physical vapor deposition methods (PVD) CVD (chemical vapor deposition) Spattering Coating High-speed frame spraying (HVOF) Spraying Resin impregnation Teflon coating Carbide Dispersion/TD Shot peening/WPC Buffing Shot blast Sound blast Water blast Glass beads blast Etching (surface treatment) Ionized plating Thermal oxidation Frame spraying Exploded spray (HEPD) Arc spray Plasma spray Dry type lubricant coating Tool and die coating DLC coating Nylon coating Deburring |
Assembly/Inspection | Assembly | Precision equipment assembly Office equipment assembly Auto parts assembly Construction component assembly Industrial machinery assembly Toy and sundries assembly |
Assembly/Inspection | Repair | Precision equipment repair Office equipment repair Auto parts repair Construction repair Industrial machinery repair Die repair Machine tool repair |
Assembly/Inspection | Inspection | Metal press Plastic Forging Casting Powder metallurgy Rubber Glass Spring Bolt/Screw/Nut Measuring |
Assembly/Inspection | Side job processing | Manual labor |
Parts manufacturing | Machinery part | Gear manufacturing Valve manufacturing Bearing manufacturing Vacuum components manufacturing Pressure container manufacturing Connection parts manufacturing Magnet containing products manufacturing Crank shaft manufacturing Optical parts manufacturing Shaft and roller manufacturing Measurement devices manufacturing pipe manufacturing Belt Ring Mechanical parts |
Parts manufacturing | Electrical part | Harness processing Cable manufacturing Connector manufacturing Cord manufacturing Other electrical part manufacturing Switch manufacturing Power-supply device manufacturing Transformer manufacturing Coil manufacturing |
Parts manufacturing | Electric board and electronic part | Rigid board Protocol and small-scale (PCB) Electronic parts assembly and wiring Flexible board manufacturing Rigid board parts mounting Flexible board parts mounting Handles one side Handles both sides Multilayer board Handles mass production Fine pattern board Impedance control system Build-up board BVH (blind via hole) IVH (inner via hole) Large current board Semiconductor and other general stock Handles short delivery Membrane switch |
Parts manufacturing | Spring | Thin leaf spring Terminal spring Compression coil spring Tensil coil spring Torsion spring Double torsion spring Leaf spring Shaped spring Battery spring Conical spring Formed wire spring Volute spring Spring washer Torsion spring Carbon steel Piano wire (carbon wire) Stainless steel Copper alloy Diameter Diameter Diameter |
Parts manufacturing | Bolt/Screw/Nut | Bolt/Screw/Nut manufacturing Screw manufacturing Bolt manufacturing Nut manufacturing Screw manufacturing |
Parts manufacturing | Other parts | Model manufacturing Lock manufacturing Sign board manufacturing Filter manufacturing Metallic mesh manufacturing Blade manufacturing Chain manufacturing |
Product manufacturing | Production property | Machine tool manufacturing Other industrial machinery manufacturing Electrical machinery and apparatus manufacturing Energy-saving equipment/Automatic instrument manufacturing Carrier machine manufacturing Packaging machinery manufacturing Measurement/testing devices manufacturing Chemical product manufacturing Cardboard box manufacturing Lubrication equipment manufacturing Brush manufacturing Optical products manufacturing Freezer equipment manufacturing Vacuum equipment manufacturing Hydraulic pressure equipment manufacturing Food industry machinery manufacturing Chemical industry machinery and equipment manufacturing Coating equipment manufacturing Fluid equipment manufacturing Industrial furnace/Test furnace manufacturing Industrial robot manufacturing Information equipment manufacturing Monitoring device manufacturing Environmental equipment manufacturing Stamp manufacturing Blade manufacturing Semiconductor manufacturing equipment manufacturing LCD manufacturing |
Product manufacturing | Plant equipment manufacturing | Plant equipment manufacturing Marine vessel equipment manufacturing Steel and furnace apparatus manufacturing Hydro/thermal/electric/atomic power generation apparatus manufacturing Large-size plant apparatus manufacturing |
Product manufacturing | Construction and civil engineering machinery manufacturing | Civil engineering machinery manufacturing Combustor manufacturing Construction and civil engineering material manufacturing Sound/fire/water proof material manufacturing Pipe connection Interior and outer wall material manufacturing Lavatory products manufacturing Water supply and discharge system manufacturing Kitchen sink manufacturing Construction machinery manufacturing |
Product manufacturing | Medical equipment manufacturing | Medical equipment manufacturing Surgical instruments Dental products Inspection and testing devices |
Product manufacturing | Household commodity | Office equipment manufacturing Bath products manufacturing Laundry products manufacturing rice-cooker and kettle manuacturing Outdoor leisure product manufacturing Cutlery Plates and glasses Storage products |
Product manufacturing | Furniture/Interior | Bedclothing manufacturing Lighting equipment manufacturing Fabric product manufacturing Leather product manufacturing Nameplates Cabinetmaking Interior manufacturing |
Product manufacturing | Craftwork/Event and ceremonial goods | Wooden product manufacturing Crockery manufacturing Paper product manufacturing Bamboo (craft) products manufacturing Stone products manufacturing Glass products manufacturing Crystal glass products manufacturing |
Product manufacturing | Machinery and product manufacturing | Paper product manufacturing |
Product manufacturing | Food industry machinery manufacturing | Food manufacturing Energy-saving fishery machinery manufacturing Energy-saving livestock-farming machinery manufacturing Other food industry machinery manufacturing |
Product manufacturing | Environmental equipment manufacturing | Waste water treatment system manufacturing Noise-reduction system manufacturing Recycling system manufacturing |
Product manufacturing | Watch/Glasses/Accessory/Jewelry | Ring manufacturing Necklace and pendant manufacturing Earring manufacturing Bracelet and buckle manufacturing Jewerly parts manufacturing |
Product manufacturing | Others | Welfare equipment manufacturing Transportation equipment manufacturing Telecommunication equipment manufacturing |
