Star21は日本ホシモトが全額出資した韓国法人であり、制御盤 キュービクル 配電盤等のキャビネット用ハンドル 、 ロック、蝶番、取手、銅ブスバーを製造販売するメーカーです。
Mechanical parts( Parts manufacturing / Machinery part ) |
Company name |
Star21 Co.,Ltd. () |
Website URL | https://www.estar21.com/ |
Street address |
Busan Republic of Korea
[See map] |
Person in charge | - |
Capital | Unregister | Employees | 20 |
Annual sales | Unregister | EMIDAS Member Number | 96544 |
Type of manufacturing | Heavy electric machinery / Industrial machinery / Electronic parts |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Rolling Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Aluminum alloy Copper alloy Bench lathe machining Brass |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining Combined lathe machining Machining (horizontal) |
Development and production of prototype/Small-scale production | Sheet-metal processing | NC set press Bending (hydraulic) Bending (servo) |
Mass production | Metal press | Bending Blanking Forming Roll forming Transfer press (below 80 t) Iron Stainless steel Thickness Thickness Transfer press (80 - 200 t) Single press (below 80 t) Single press (80 - 200 t) Progressive press (35 - 80 t) Progressive press (80 - 200 t) |
Mass production | Die-casting | 125 t or less 125 - 250 t Zinc |
Mass production | Forging | Header machining Hot forging Cold forging Iron Below 500 g 500 g - 5 kg |
Mass production | Casting | Lost-wax Zinc alloy 500 g and below Over 500 g and less than 5 kg |
Mass production | Sheet-metal processing | NC set press Bender processing (flood control) Bender processing (servo) Bending process |
Surface treatment | Plating/Chemical conversion treatment | Nickel (barrel) Tin (barrel) Copper (barrel) Chromium (barrel) Zinc (barrel) Chromate (general) Nickel (rack) Tin (rack) Copper (rack) Chromium (rack) Zinc (rack) Nickel chromium (rack) Tin-zinc alloy plating (rack) Trivalent Chromate (barrel plating) Iron Copper Brass Zinc die-cast Stainless steel Unichromate (white) Colored chromate (multi-color) |
Parts manufacturing | Machinery part | Mechanical parts |
