Industrial machinery
KOLEC
Products lineup: 5 different load weight from 400kg to 1.5t
Easy operation. Safety device fully equipped.
FORKLIFT COUNTER
Preventing an operator from being sandwitched by the forklift, the safety switch is equipped. When the forklift is being driven in the operator's direction and the switch is depressed, the direction will be reversed and the forklift will be driven the opposite direction in order to avoide trapping the operator.
While the forklift is being driven, brake can easily be applied simply by positioning the control handle vertical/fully raised or horizontal/fully lowered.
Load handling can be done gently as the forklift is operated by manually. Power steering for easy operation is one of the standard features. (on FX15WT) Double-sided pallets can be used as the forklift does not have forelegs.
We provide a variety of models to meet your requirements:
Single Stage, Two Stage, with Tilt, without Tilt, and others
Smoth drive with AC control. Hour meater and battery indicator equipped.
The control handle is designed based on ergonomics.
It is designed for safer operation and drive, and the handle shape was designed to reduce stress. The forklift is designed operator-friendly. Muscle labor is not necessary.
Rubber skirt, as a safety equipment, is featured on all models.
Easy maintenance and daily check-ups.
Cover will open all the way, making maintenance and daily check-ups easy.
All operations at the control handle.
(for and FX15WT)
No step control system for driving speed. Driving can be controled at an extremely low speed.
Operation can be done very simply.
(FX6, FX9)
Hydroulic lever
(FX6, FX9)
Driving speed can be extremely low as the forklift is equipped with the hydroulic control lever.
Common options through all models
Warning beep while traveling
Back-up buzzer
Fork length can be altered.
Uplift limitation switch
Forl extension sleeves
Step (FX6, FX9)
Foldable step for the operator to drive standing on it (with dead man brake)
Jib crane customization
Fork height can be altered
Wide carriage
No tilt
*Please contact us for other customization.
Company name | Thai Nakanishi Co., Ltd. | EMIDAS Member Number | 95833 |
Country | Kingdom of Thailand | Street address |
Bangrak Bangkok Kingdom of Thailand |
Telephone number | +-2-236-3102 | Fax number | +-2-236-4889 |
Employees | 100,000,000 THB | Annual sales | |
Employees | 23 | Person in charge | Kod (Mr.) |
Type of manufacturing | Industrial machinery / Transportation equipment | ||
Primary clients |
