Industrial machinery
KOLEC
Walkie counterbalanced stackers
Walkie counterbalanced stackers Walkie counterbalanced stackers work by electric drive and electric lift in safety. You can control drive and lift operation by centralized control hand device. You can load this walkie into elevator, because of light weight and compact size. And this walkie accepts any pallets.
FX Series
Electric Travel / Electric lift / Load capacity 600 / 900 / 1500 kg
Easy operation in safety
Efficient and easy control by centralized control hand device
A sandwiched protection switch is standard equipment. If an operator is sandwiched between the truck and wall, the switch is pushed and the truck moves to a fork mounted side.
Brake function when the handle is moved to stopping position which is standing position and horizontal position.
In the specification of lifting height 2,480mm, the stepless speed variator (chopper) is standard equipment. The equipment realizes smooth drive.
Fork lifting speed control is available by turning radius of control knob.
Fork can be held, so the over length make shorter. It can be loaded into elevator.
Company name | Thai Nakanishi Co., Ltd. | EMIDAS Member Number | 95833 |
Country | Kingdom of Thailand | Street address |
Bangrak Bangkok Kingdom of Thailand |
Telephone number | +-2-236-3102 | Fax number | +-2-236-4889 |
Type of manufacturing | Industrial machinery / Transportation equipment / Not selected | Employees | 100,000,000 THB |
Annual sales | Employees | 23 | |
Person in charge | Masuda (Mr.) | Primary clients |
