PR message
Enshu Vietnam is the representative of Enshu brand in Vietnam market in security, maintenance and repair of tools manufactured and assembled by Enshu with various models.
GE580He
High-speed, high-rigidity horizontal machining center capable of heavy cutting
feature :
--No. 50 general-purpose horizontal machining center for heavy cutting
--Highly matured high speed and high rigidity
--Further increase in rigidity with the new column
--Wide stroke of 800 mm for each axis
WE30Ve
Fusion of high performance and functional beauty
feature :
--High torque motor of the highest level in its class
--Highly rigid gate-shaped column structure
--Large capacity and easy-to-use processing area
--Machine configuration with sufficient consideration for jig mounting
Company name | ENSHU VIETNAM CO.,LTD. | Website URL | |
Street address |
Tu Son Town Bac Ninh Socialist Republic of Vietnam
[See map] |
Person in charge | NGUYEN VAN HUNG |
Telephone number | Log in to display | Fax number | Log in to display |
Capital | 9,000,000 $ | Employees | 200 |
Annual sales | 11,460,000 $ | EMIDAS Member Number | 95722 |
Type of manufacturing | Transportation equipment / Machine tools | ||
Main 3 products |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Blank cutting | Cutting Copper/Aluminum |
Mass production | Metal press | Multi forming Coining |
Mass production | Casting | Aluminum bronze alloy |
Surface treatment | Plating/Chemical conversion treatment | Iron |
Surface treatment | Heat treatment | Flame quenching Solution heat treatment |
