Injection molding die( Designing / Mold designing ) |
Fine particle material accepted( Mass production / Mechanical processing ) |
Handles 3D processing( Development and production of prototype/Small-scale production / NC machining ) |
Machining( Mass production / Mechanical processing ) |
Machining (vertical)( Development and production of prototype/Small-scale production / NC machining ) |
Form grinding( Development and production of prototype/Small-scale production / Grinding processing ) |
Profile grinding( Development and production of prototype/Small-scale production / Grinding processing ) |
Company name | CPTD MALAYSIA SDN.BHD. | Website URL | |
Street address |
Lorong P/AM 2/1 Arab Malaysian Industrial Park 71800 Nilai, Negeri Sembilan Negeri Sembilan Malaysia
[See map] |
Person in charge | Hiroyuki Ogino |
Telephone number | 60-6-799-7712 | Fax number | 60-6-799-0171 |
Capital | 54,000,000 JPY | Employees | 34 |
Annual sales | 270,000,000 JPY | EMIDAS Member Number | 95678 |
Type of manufacturing | Jigs and tools | ||
Main 3 products |
PR message
CPTD MALAYSIA SDN. BHD. presents precision processing technology that can accommodate a wide range of materials from Special Steel to Ceramic, to meet the demands of every industry. By using advanced processing technology and capabilities in handling diverse materials, we produce products that meet our customers' needs.
Most recent update:2024-03-07
Large | Medium | Small |
Designing | Mold designing | Injection molding die 3D modeling (plastic) |
Designing | Simulation | CAE fluid analysis |
Development and production of prototype/Small-scale production | Machining | General-purpose milling Tapping Profile milling Straightening Machining/Handles small-scale production (order from 1 piece) Iron High rigid material Copper alloy Sintered metal Keyway milling Router machining Air chuck equipment Handles microfabrication Handles microfabrication |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling Boring milling Handles 2.5-dimensional processing Handles 3D processing |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining Micro hole machining Electric discharge machining |
Development and production of prototype/Small-scale production | Grinding processing | NC plane grinding Plane grinding Form grinding Profile grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | YAG laser machining |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Welding jig manufacturing Mass production jig manufacturing Jig and tool manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Small-size prototype manufacturing Prototype/Small-lot molding Small-lot/Injection molding Simplified/Molding prototype mold |
Die manufacturing | Plastic mold | Designing Manufacturing Part processing Plate machining NC data creation 3D modeling Injection molding die Plastic magnet molding die Below 60 t 60 - 300 t Electrode manufacturing Cassette-type molding die Injection molding die for microfabrication (5 mm or smaller) Core and cavity machining |
Die manufacturing | Rubber mold | Rubber mold part processing Part processing Compression molding die Blanking die Home electrical appliances Medical |
Die manufacturing | Forging die | Manufacturing Forging die part processing NC data creation Hot forging die Cold forging die |
Die manufacturing | Casting die | Manufacturing Die-casting part processing NC data creation 3D modeling Die-casting die |
Mass production | Mechanical processing | Machining NC milling machining Tapping machining Wire machining Micro-hole machining Electrical discharge machining Iron Cemented carbide Sintered metal Air chuck equipment Fine particle material accepted High precision |
Surface treatment | Polishing/Lapping | Tool polishing Buffing Mirror polishing |
Surface treatment | Printing and others | NC engraving |
Surface treatment | Lap polishing | Lap polishing Lap mirror polishing Single-face lapping and polishing |
