Industrial machinery
Kawasaki Thermal Engineering Co., Ltd.
Pursuing high performance and high quality - NES series
Efficio NES series
- Reduction of steam consumption rate
- Higher partial load efficiency and system efficiency
- Suitable for replacement
High level energy saving :
NES series is designed based on our high efficiency model, Efficio series, applying compact high-performance heat exchanger and high-performance heat exchanger tube. And high-temperature generator and drain economizer are newly designed.
Steam consumption rate at full load operation is reduced to 3.8 kg/h RT.
Compared to the conventional model, the steam consumption at full load is reduced by 19%.
Higher partial load efficiency :
The solution pump inverter control is equipped as standard and it enables efficient operation across various range of load condition from low to high, which contributes to high partial load efficiency.
Higher system efficiency :
Applying energy-saving function of Efficio series, we achieve higher system efficiency including auxiliary equipment.
The lower limit flow rate of cooling water when controlling the variable flow rate is expanded to 30% from 50%.
It contributes reducing power consumption of cooling water pump.
Company name | Kawasaki Heavy Industries (Thailand) Co., Ltd. Thermal Engineering Division | EMIDAS Member Number | 95651 |
Country | Kingdom of Thailand | Street address |
Bangrak Bangkok Kingdom of Thailand |
Telephone number | +66-66-83-807-7894 | Fax number | +66-66-2-163-2841 |
Employees | Annual sales | ||
Employees | 10 | Person in charge | Kamitori |
Type of manufacturing | Industrial machinery | ||
