Auto electrical parts
Light electrical/Home electrical appliance
Electronic parts
Metal Oxide Film Fixed Resistors
FEATURES
Having a Flame-proof coating, this insulated type will not burn under its own
heat generation or by an external flame.
Conform RoHS
APPLICATIONS
TV, VCR, Audio, and other Consumer Equipment, as well as Printers and other
Terminal Equipment, Car Audio, Communication Equipment, Measuring
Equipment, and other Industrial Equipment.
Fusing Resistors
FEATURES
Functions as a resistor usually.
If an abnormal overload is impressed, RNF fuses promptly, and protects the
circuit.
Conform RoHS
APPLICATIONS
AV equipment such as TV and Videos, General electric product.
Surge Resistor
FEATURES
RMH is a resistor by which the circuit damage by the rushing into current such
as the inducement thunders is reduced.
Recognition passing goods of UL,BSI,VDE standard.
Conform RoHS
APPLICATIONS
Power supply circuit, High voltage circuit, etc
Thermal Fuse Resistor
FEATURES
These safety resistors incorporate a thermal fuse (a tinlead alloy type or
organic-compound pellet type) inside a cement-filled wire-wound resistor,
consolidated into a single device.
By virtue of the built-in thermal fuse being adjacent to the resistor element, the
dispersion in fusing characteristics has been minimized and assures a high
stability performance.
Excels in surge withstanding capabilities.
RGDU2M and RGDU5M and RGDU7M are UL recognized.
(UL-1412 File No.E62418)
Conform RoHS
APPLICATIONS
Power Supplies, Printers, Copy Machines, Microcomputers etc.
Cement-Filled Fixed Resistors
FEATURES
Being an incombustible insulated type, will not start a fire when overloaded.
Assures a high level of safety.
Conform RoHS
Company name | NOBLE ELECTRONICS VIET NAM CO.,LTD | EMIDAS Member Number | 95575 |
Country | Socialist Republic of Vietnam | Street address |
Thach That Ha Noi Socialist Republic of Vietnam |
Telephone number | Log in to display | Fax number | Log in to display |
Employees | 5,000,000 $ | Annual sales | 2,000,000,000 JPY |
Employees | 350 | Person in charge | Tomoyoshi Tsubuki |
Type of manufacturing | Electronic parts |
