Teikoku Tsushin Kogyo Co.,Ltd. was established in 1944 as a broad scale electronics manufacturer,
providing a wide variety of circuit control components such as resistors, sensors,
and switches under the NOBLE brand.
PR message
Seeking to carry out as much of the manufacturing process independently in order to become a manufacturer of choice.
Since 1944, NOBLE has strived to improve upon the development and manufacturing of electronic components found in everyday products like home appliances, health care devices and automotive, through our manufacturing of electronic components.
We were founded on the goal of in-house design and manufacturing and have continued to refine our technologies.
Metal Oxide Film Fixed Resistors
FEATURES
Having a Flame-proof coating, this insulated type will not burn under its own
heat generation or by an external flame.
Conform RoHS
APPLICATIONS
TV, VCR, Audio, and other Consumer Equipment, as well as Printers and other
Terminal Equipment, Car Audio, Communication Equipment, Measuring
Equipment, and other Industrial Equipment.
Fusing Resistors
FEATURES
Functions as a resistor usually.
If an abnormal overload is impressed, RNF fuses promptly, and protects the
circuit.
Conform RoHS
APPLICATIONS
AV equipment such as TV and Videos, General electric product.
Surge Resistor
FEATURES
RMH is a resistor by which the circuit damage by the rushing into current such
as the inducement thunders is reduced.
Recognition passing goods of UL,BSI,VDE standard.
Conform RoHS
APPLICATIONS
Power supply circuit, High voltage circuit, etc
Thermal Fuse Resistor
FEATURES
These safety resistors incorporate a thermal fuse (a tinlead alloy type or
organic-compound pellet type) inside a cement-filled wire-wound resistor,
consolidated into a single device.
By virtue of the built-in thermal fuse being adjacent to the resistor element, the
dispersion in fusing characteristics has been minimized and assures a high
stability performance.
Excels in surge withstanding capabilities.
RGDU2M and RGDU5M and RGDU7M are UL recognized.
(UL-1412 File No.E62418)
Conform RoHS
APPLICATIONS
Power Supplies, Printers, Copy Machines, Microcomputers etc.
Cement-Filled Fixed Resistors
FEATURES
Being an incombustible insulated type, will not start a fire when overloaded.
Assures a high level of safety.
Conform RoHS
FEATURES
Compact.
2.5mm stroke which checks visually and is good.
Conform RoHS
APPLICATIONS
Various switch modes,secondary circuits and signal level switching.
TV, AV Equipment, Personal computer, Car air conditioner
FEATURES
High performance switches created by incorporating NOBLE’s Film
Integration Technology.
Film element provides smooth rotational feeling.
Conform RoHS
FEATURES
Space Saving Size
Easily adjusts with standard screwdriver.
Metal-glaze resistance element gives excellent stability and protection
against environmental factors.
Can be mounted to a circuit board with adhesive.
Designed for reflow soldering.
Supplied in 8mm tape for automatic assembly equipment.
Conform RoHS
APPLICATIONS
Video equipment, industrial equipment and other general electronic
equipment.
Rotary potentiometer
FEATURES
High performance miniature potentiometer created by incorporating NOBLE's Film
Confrom RoHS
APPLICATIONS
Component stereo, Audio mixer, Speaker volume adjustment, Visual
equipment, Electronic musical instruments.
Slide potentiometer
FEATURES
All series are united by the width of 9mm.
Excellent slide operation feeling
An auto dip can correspond.
Conform RoHS
APPLICATIONS
Volume & Tone quality adjustment such as audio mixers.
Rotary type
FEATURES
Ultra-long Life Potentiometer developed for game machines.
Excellent smooth operation low torque.
Conform RoHS
APPLICATIONS
Controllers for Video Game.
Position Sensors for Personal robot.
Slide type
FEATURES
Light slide feel and excellent operation.
APPLICATIONS
Volume adjustment for game machines, etc.
Rotary type
FEATURES
With the use of new substrate materials, reflow durability has been improved compared to conventional products.
Used as a contact sensor, it provides long-life slide durability.
APPLICATIONS
Game machines, position sensor,
Servo motor for radio control
Slide type
FEATURES
This is thin type slide potentiometer which is most suitable as a linear sensor. (±0.5% of Linearity is possible)
Light slide feeling and quick reaction (Slide torque 0.25N or less)
Little influence of the outside noise to compare with optics type.
Conform RoHS
APPLICATIONS
Position detecting of lens, etc
Trapezoidal distortion correcting for projector
Angle and position adjustment for other mechatronics products
Curve Slide type
FEATURES
A tin potentiometer that slids along curved surface.
Quick reaction with smooth sliding motion. (Linearity ± 1%)
Conform RoHS
Custom made product
APPLICATIONS
Position detection of lens and other optics.
Detection of angles and positions for products with curved surface.
The electronics industry is rapidly evolving, with a primary driver expressed simply by the word of “IoT”. Adaption to ever changing and advancing sensor technology addition to our company strength of man machine interface development is a must.
In response to industry changes, we strive by an eternal theme of KAIZEN, KAIRYO and KAIKAKU for continuing production innovation.
The collaboration beyond sections is a requirement for production innovation.
I engaged in production engineering for many years.
It has been my mission to strengthen department ties. There is no doubt that greater importance will be placed on electrical component technology in the fields of automotive electronics, home appliances, medical/healthcare, robotics, and a host of other areas in the future.
Our goal will be new product development and sales expansion with a strong focus on sensor technology driven by market requirements. At the same time, our aim will be maintaining current technology and development without any compromise.
Please expect on seeing our company in tomorrow's electronics.
Company name | NOBLE ELECTRONICS VIET NAM CO.,LTD | Website URL | https://www.noble-j.co.jp/ |
Street address |
Thach That Ha Noi Socialist Republic of Vietnam
[See map] |
Person in charge | Tomoyoshi Tsubuki |
Telephone number | Log in to display | Fax number | Log in to display |
Capital | 5,000,000 $ | Employees | 350 |
Annual sales | 2,000,000,000 JPY | EMIDAS Member Number | 95575 |
Type of manufacturing | Electronic parts | ||
Main 3 products |
Large | Medium | Small |
Designing | Electrical planning | Electrical machinery and apparatus designing PCB designing Other electronic part designing Eletronic circuit designing |
Parts manufacturing | Electrical part | Other electrical part manufacturing Power-supply device manufacturing |
Parts manufacturing | Electric board and electronic part | Electronic parts assembly and wiring Fine pattern board Build-up board |
