Measuring equipment and testing machine
Rockwell Hardness Tester
The Rockwell hardness test measures hardness from the depth of an indentation created by pressing a diamond indenter against a sample. It is often used to check the hardness of metal parts after heat treatment. The Rockwell hardness test is ideal for testing quenching, tempering, carburizing, and nitriding.
Product Name: Rockwell Hardness Tester HR-110
Manufacturer: Mitutoyo Measurable Range: Maximum Dimensions
Depth 165mm x Height 180mm
Examples of Uses
1. Hardness testing of heat-treated fabricated metal parts
2. Validating the presence or absence of heat treatment
Company name | Agency Assist Vietnam Co.,Ltd | EMIDAS Member Number | 95522 |
Country | Socialist Republic of Vietnam | Street address |
Can Giuoc District Long An Socialist Republic of Vietnam |
Telephone number | Log in to display | Fax number | Log in to display |
Employees | 6,330,000,000 VND | Annual sales | 3,000,000,000 JPY |
Employees | 132 | Person in charge | 吉岡 大祐 |
Type of manufacturing | Machine tools / Industrial machinery / Transportation equipment | ||
Primary clients |
