Saw blade grinding machine: TN-30 Chip saw body grinding machine
Features
Conventional blade shaping of chip saw blades was mainly done by hand-grinding. This caused the original blade shape to collapse and become unbalanced, resulting in vibration and rough cutting surfaces.
The features of this machine are...
1. it maintains balance and can shape the base metal beautifully and efficiently.
2. no feed jaws are used and the indexing device is controlled so that grinding can be done even if chips are present.
3. touch screen operation for easy operation. 4.
4. automatic infeed in increments of 0.1mm and automatic stop after grinding is completed.
The border between the chip and the base metal can be adjusted freely, and the height of the chip can be adjusted as desired.
The chip saw grinder manufactured by our company is supported and used by many chip saw manufacturers and regrinders throughout Japan. Our machines are also used in Taiwan, China and other countries.
Company name | Tokai Saw (Thailand) Co., Ltd. | EMIDAS Member Number | 95280 |
Country | Kingdom of Thailand | Street address |
A.Bangsaothong Samut Prakan Kingdom of Thailand |
Telephone number | +-66-2-315-3575 | Fax number | +-66-2-315-3576 |
Employees | 10,000,000 THB | Annual sales | |
Employees | 10 | Person in charge | Tanonglit (Mr.) |
