Saw blade grinding machine: TN-8 Chip saw grinding machine (for escape only)
Features
1. various settings are set by touch panel
2. even grinding of triple surface can be set at once
Height difference of paired teeth can be set numerically (1/100mm unit).
4. wheel spindle rotates directly by special motor
5. special motor for direct rotation of grinding wheel up to approx. 1.6 hp
Sharpenable blade type
1. flat tooth
2. alternating teeth
3. paired teeth (flat teeth followed by several pairs of alternating teeth)
4. triple (45° three-sided blade type)
5. single-sided
6. triangular tooth
Our chip saw sharpening machines are supported and used by many chip saw manufacturers and re-sharpeners throughout Japan. Our machines are also used in many other countries such as Taiwan and China.
Translated with www.DeepL.com/Translator (free version)
Company name | Tokai Saw (Thailand) Co., Ltd. | EMIDAS Member Number | 95280 |
Country | Kingdom of Thailand | Street address |
A.Bangsaothong Samut Prakan Kingdom of Thailand |
Telephone number | +-66-2-315-3575 | Fax number | +-66-2-315-3576 |
Type of manufacturing | Not selected / Not selected / Not selected | Employees | 10,000,000 THB |
Annual sales | Employees | 10 | |
Person in charge | Tanonglit (Mr.) | Primary clients |
