Machine tools
Jigs
Manufacturing facilities
Carton erector and sealing machine Model: MK-GB30
- As a line of automatic box opening machine suitable for many types of cartons, the machine has a box-shaped carton structure that uses a gas source >500L/min, 0.4~0.8 Mpa to work.
- The machine is stable, accurate, quiet and durable. When using the machine, customers will shorten the time for opening the box to increase productivity… The machine uses a PLC controller that allows the machine to work stably and accurately, in addition, the machine is easy to use without high qualifications. machine can also be used.
**Product Specifications:
- Carton size: L200-500/W200-460/H200-400mm
Table height: 600mm
- Air pressure: 500L/min: 0.4~0.8 Mpa
- Power supply: 3 phase 220-380V/50-60Hz/ 0.2kw
Machine weight: 380kg
**Contact Mikyo for detailed advice:
+ Hotline: +84 918.808.795, +84 918.000.267
+ Head office: Mikyo Hanoi: Lot 5.6 Lai Xa Industrial Park, Kim Chung, Hoai Duc, Hanoi.
+ Ho Chi Minh Branch: Lot 6, Binh Chieu Industrial Park, Thu Duc, Ho Chi Minh.
Company name | MIKYO PACKING MACHINERY JOINT STOCK COMPANY | EMIDAS Member Number | 95122 |
Country | Socialist Republic of Vietnam | Street address |
Hà Nội Ha Noi Socialist Republic of Vietnam |
Telephone number | +-+84918808795 | Fax number | +-+84918808795 |
Employees | 1,000,000 $ | Annual sales | 500,000 $ |
Employees | 50 | Person in charge | Luong Nhu Cuong |
Type of manufacturing | Jigs and tools / Machine tools / Industrial machinery | ||
Primary clients |
