Most recent update: 2022-10-13
3D laser machining( Development and production of prototype/Small-scale production / Blank cutting ) |
Company name |
株式会社 石川技研工業 (Kabushikikaisha ishikawagikennkougyou) |
Website URL | http://gikenkougyou.com/ |
Street address |
Hokkaido Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 16 |
Annual sales | Unregister | EMIDAS Member Number | 94994 |
Type of manufacturing | Industrial machinery / Construction material / Transportation equipment |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | Tapping Iron Stainless steel |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Precision sheet metal machining Sheet metal protocol manufacturing Bending (over 3.0 m) Angle machining Pipe bending 3-roll bending Bending (hydraulic) Bending (servo) 3D pipe machining |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing Cutting Laser processing (longer than 121.2 m) Shearing (longer than 121.2 m) Corner shearing CO2 laser machining Laser marking Nitrogen cutting Stainless steel Copper/Aluminum 3D laser machining |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding TIG welding (argon welding) Arc welding |
Development and production of prototype/Small-scale production | Jig manufacturing | Welding jig manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Punching Welding Bending Small-size prototype manufacturing Prototype/Small-lot molding |
Development and production of prototype/Small-scale production | Blank cutting | Laser marking Turret punch punching Shirring Cutting process Laser processing (over 1.2m) Shirring (more than 1.2m) Connor Shah CO2 laser processing Thick plate 6 mm or more stainless Copper / aluminum 3D laser |
Mass production | Metal press | Bending Blanking Iron Stainless steel Aluminum Copper Plated steel plate Thickness Thickness Thickness |
Mass production | Sheet-metal processing | Pipe processing Precision sheet metal processing Sheet metal prototype manufacturing Bender processing (over 3.0m) Angle processing Pipe bender processing 3-roll machine Bender processing (flood control) Bender processing (servo) 3D pipe processing Thin (t0.5 or less) / Small sheet metal processing Bending process |
Mass production | Blank cutting | Laser marking Turret punch punching Shirring Cutting process Laser processing (over 1.2m) Shirring (more than 1.2m) Connor Shah CO2 laser processing Thick plate 6 mm or more stainless Copper / aluminum 3D laser |
Mass production | Welding / welding | CO2 welding TIG welding (argon welding) Arc welding |
Assembly/Inspection | Assembly | Construction component assembly Industrial machinery assembly |
Parts manufacturing | Other parts | Sign board manufacturing |
Auto parts manufacturing | Body part | Other body parts |
