"We are introducing trial processing example of resin products for automobiles.
This product is made of a material called PPS-GF40 (polyphenylene sulfide resin). A crystalline super engineering plastic containing glass fiber and carbon fiber which has excellent heat, fire and chemical resistance, and widely used in various industries such as motor parts, coil bobbins, joints, etc.
The product in the front has conical lugs, and claws on the left and right. The product in the back has holes and claw holders, and each product has taper. It has a snap-fit claw fitting structure to click each other. It fits into a housing of about 25 mm x 50 mm x 190 mm. You can open and close it as many times as you like by removing the claws and lugs.
We used 5-axis machining center for both first and second machining process. Since it contains glass and carbon fiber, cracks are likely to occur during processing, so we adjusted the processing procedure and conditions many times.
The fitting parts such as claws are finely machined from Φ2mm to Φ1mm end mill, from R0.75mm to R0.5mm ball end mill, and are finished neatly with the utmost care.
We are mainly processing metals, but we also have a lot of experience in processing resin products such as PPS materials, vinyl chloride, MC nylon, etc. We are handling wide range from metal to resin, so please contact us if you have any problems.
<External dimensions>
25mm x 50mm x 190mm
Maximum size 500mm x 1,000mm x 380mm
<Materials we can handle>
A5052, A2024, A7075, S45C, S50C, NAK55, SUS303, SUS304,
vinyl chloride, MC nylon, Duracon, glass epoxy, bakelite, etc.
<CAD format we can accept>
Parasolid (x_t, x_b), STEP (STP), ACIS (SAT), DWG, DXF, IGES (IGS)"
Company name | SIT Co., Ltd. | EMIDAS Member Number | 94902 |
Nikaho City Akita Japan |
Telephone number | Log in to display | Fax number | Log in to display |
Employees | 30,000,000,000 JPY | Annual sales | |
Employees | 13 | Person in charge | 齋藤 長之 |
Type of manufacturing | Jigs and tools / Industrial machinery |
