Most recent update: 2024-02-25
Bender processing (servo)( Mass production / Sheet-metal processing ) |
Company name |
株式会社 池田機工 (Ikedakikou) |
Website URL | http://ikeda-kikou.jp |
Street address |
Niigata Japan
[See map] |
Person in charge | - |
Capital | 29,000,000 JPY | Employees | 40 |
Annual sales | Unregister | EMIDAS Member Number | 94874 |
Type of manufacturing | Industrial machinery / Telecommunication equipment / Medical equipment |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Thread-cutting Spinning Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Aluminum alloy Copper alloy Machining (resin) Automatic lathe Milling (resin) Lathe machining (resin) Brass |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining Machining (horizontal) |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Can manufacturing Air-conditioning equipment manufacturing Kitchen unit manufacturing NC set press Precision sheet metal machining Chassis manufacturing Sheet metal protocol manufacturing Bending (over 3.0 m) Angle machining Pipe bending Deburring Coating Mirror surface machining Hair line machining 3-roll bending Bending (hydraulic) Bending (servo) 3D pipe machining Thin wall (Thickness |
Development and production of prototype/Small-scale production | Blank cutting | YAG laser machining Turret punch press processing Shearing Cutting Laser and turret punch press processing Laser processing (longer than 121.2 m) CO2 laser machining Nitrogen cutting Thin plate (below 6 mm) Thick plate (over 6 mm) Stainless steel Copper/Aluminum Fiber laser processing |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Arc welding Robot welding Brazing Stud welding YAG laser machining Fiber welding Projection welding |
Die manufacturing | Press die | Designing Manufacturing Part processing Plate machining Die set machining NC data creation Drawing die Bending die Blanking die Fine blanking die Shaving die Single press die Below 60 t 60 - 300 t Compound die |
Mass production | Metal press | Drawing Bending Blanking Forming Multi forming Shaving Coining Transfer press (below 80 t) Iron Stainless steel Aluminum Copper Brass Phosphor bronze Plated steel plate Stainless steel material for spring Thickness φ0.6mm - φ9.0mm Combined press-joining Beryllium copper Press robot (below 80 t) Single press (below 80 t) Single press (80 - 200 t) Single press (200 - 500 t) Progressive press (35 - 80 t) Progressive press (80 - 200 t) Progressive press (200 - 500 t) |
Mass production | Mechanical processing | Machining NC turning machining Tapping machining Wire machining Iron Stainless Aluminum alloy Copper alloy Automatic screw machining |
Mass production | Sheet-metal processing | Pipe processing Can-making Air conditioning equipment manufacturing Kitchen equipment manufacturing NC set press Precision sheet metal processing Housing manufacturing Sheet metal prototype manufacturing Bender processing (over 3.0m) Angle processing Pipe bender processing Deburring process Painting process Mirror surface material processing Hairline processing 3-roll machine Bender processing (flood control) Bender processing (servo) Bending process |
Mass production | Blank cutting | Turret punch punching Laser and turret punch punching Laser processing (over 1.2m) CO2 laser processing Fiber laser processing Clean cut Thin plate 6 mm or less Thick plate 6 mm or more stainless Copper / aluminum |
Mass production | Welding / welding | Projection welding CO2 welding Fiber welding Spot welding TIG welding (argon welding) Arc welding Robot welding fixing with wax Stud welding YAG laser processing |
Surface treatment | Plating/Chemical conversion treatment | Nickel (barrel) Chromate (general) Nickel (rack) Chromium (rack) Acid pickling Parkerizing (phosphate film) Electroless nickel (barrel) Electroless nickel (rack) Chemical conversion coating Trivalent Chromate (barrel plating) Iron Copper Brass Aluminum Stainless steel Hard chromium (rack) Degreasing Black oxide finish Hard alumite Unichromate (white) Black chromate (black/green) Colored chromate (multi-color) |
Surface treatment | Coating | Powder coating Resin coating Electrodeposition coating Electrostatic coating Melamine coating Urethane coating Acrylic coating Heat-resistant coating |
Surface treatment | Polishing/Lapping | Electropolishing Chemical polishing Buffing Mirror polishing |
Surface treatment | Printing and others | Silk screen printing |
Surface treatment | Heat treatment | Quenching |
Surface treatment | Barrel polishing | Barrel finishing (vibration) Barrel finishing (rotation) Barrel finishing (centrifugal) |
