Most recent update: 2022-04-18
Company name |
株式会社 ナ・デックスプロダクツ (Nadekkusupurodakutsu) |
Website URL | http://www.nadex-p.jp |
Street address |
Gifu Japan
[See map] |
Person in charge | - |
Capital | 98,350,000 JPY | Employees | 165 |
Annual sales | Unregister | EMIDAS Member Number | 94675 |
Type of manufacturing | Machine tools / Industrial machinery / Electronic parts |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Sheet-metal processing | Can manufacturing NC set press Precision sheet metal machining Chassis manufacturing Deburring Coating Hair line machining Bending (hydraulic) Bending (servo) |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing Cutting Laser and turret punch press processing CO2 laser machining Thin plate (below 6 mm) Stainless steel Copper/Aluminum |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Arc welding Stud welding |
Mass production | Sheet-metal processing | Can-making Precision sheet metal processing Housing manufacturing Sheet metal prototype manufacturing Deburring process Painting process Hairline processing Bending process |
Mass production | Blank cutting | Turret punch punching Shirring Cutting process Laser and turret punch punching CO2 laser processing Thin plate 6 mm or less stainless Copper / aluminum |
Mass production | Welding / welding | CO2 welding Spot welding Arc welding Stud welding |
Surface treatment | Plating/Chemical conversion treatment | Nickel (barrel) Copper (barrel) Zinc (barrel) Nickel (rack) Copper (rack) Zinc (rack) Alumite (anode oxidation) Acid pickling Electroless nickel (barrel) Electroless nickel (rack) Tin-zinc alloy plating (rack) Trivalent Chromate (barrel plating) Iron Aluminum Stainless steel Degreasing Black oxide finish Hot-dip galvanizing (small-size Hot-dip galvanizing (mid-size Nickel (hoop) |
Surface treatment | Coating | Powder coating Electrostatic coating Melamine coating Acrylic coating Epoxy coating |
Surface treatment | Polishing/Lapping | Electropolishing |
Surface treatment | Printing and others | Silk screen printing |
Parts manufacturing | Electrical part | Harness processing Cable manufacturing Connector manufacturing |
Parts manufacturing | Electric board and electronic part | Protocol and small-scale (PCB) Electronic parts assembly and wiring Rigid board parts mounting Handles one side Handles both sides Multilayer board |
