Most recent update: 2020-10-08
Precision sheet metal machining( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Company name |
トーカイサポート 株式会社 (To-kaisapo-to) |
Website URL | https://tokaisaport.co.jp/ |
Street address |
Gifu Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 20 |
Annual sales | EMIDAS Member Number | 94673 | |
Type of manufacturing | Heavy electric machinery / Industrial machinery / Construction material |
Large | Medium | Small |
Designing | Data creation (3D scan) | Data creation (3D scan) |
Development and production of prototype/Small-scale production | Machining | Melt cutting General-purpose milling General-purpose lathe machining Tapping Thread-cutting Iron Stainless steel Aluminum alloy Copper alloy Router machining Brass |
Development and production of prototype/Small-scale production | NC machining | Handles 3D processing |
Development and production of prototype/Small-scale production | Sheet-metal processing | Can manufacturing Air-conditioning equipment manufacturing NC set press Precision sheet metal machining Chassis manufacturing Sheet metal protocol manufacturing Bending (over 3.0 m) Angle machining Pipe bending Deburring Coating Mirror surface machining Hair line machining 3-roll bending Bending (hydraulic) Can manufacturing (over 5 m) Thin wall (Thickness |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing Cutting Laser and turret punch press processing CO2 laser machining Laser marking Etching Nitrogen cutting Thin plate (below 6 mm) Thick plate (over 6 mm) Stainless steel Copper/Aluminum Precision cutting 3D laser machining Fiber laser processing |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Arc welding Robot welding Brazing Stud welding Capacitator spot welding Fiber welding Projection welding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Welding jig manufacturing Mass production jig manufacturing Jig and tool manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Punching Welding Bending Small-size prototype manufacturing Chassis prototype manufacturing Model manufacturing |
Development and production of prototype/Small-scale production | Blank cutting | Laser marking Turret punch punching Shirring Cutting process Laser and turret punch punching Shirring (more than 1.2m) CO2 laser processing Fiber laser processing Clean cut Thin plate 6 mm or less Thick plate 6 mm or more stainless Copper / aluminum Precision cutting 3D laser |
Mass production | Metal press | Drawing Bending Blanking Shaving Iron Stainless steel Aluminum Copper Brass Plated steel plate Thickness Thickness Thickness Combined press-joining Single press (below 80 t) |
Mass production | Mechanical processing | Machining Tapping machining Wire machining Iron Stainless Aluminum alloy Copper alloy Titanium High precision |
Mass production | Sheet-metal processing | Can-making Air conditioning equipment manufacturing Precision sheet metal processing Housing manufacturing Sheet metal prototype manufacturing Bender processing (over 3.0m) Angle processing Pipe bender processing Deburring process Mirror surface material processing Hairline processing 3-roll machine Bender processing (flood control) Can making (more than 5m) Thin (t0.5 or less) / Small sheet metal processing Bending process |
Mass production | Blank cutting | Laser marking Turret punch punching Shirring Cutting process Laser and turret punch punching Shirring (more than 1.2m) CO2 laser processing Fiber laser processing Clean cut Thin plate 6 mm or less Thick plate 6 mm or more stainless Copper / aluminum Precision cutting 3D laser |
Assembly/Inspection | Assembly | Office equipment assembly Construction component assembly Industrial machinery assembly |
Assembly/Inspection | Inspection | Measuring |
Assembly/Inspection | Side job processing | Manual labor |
Parts manufacturing | Electrical part | Coil manufacturing |
Product manufacturing | Production property | Machine tool manufacturing Other industrial machinery manufacturing Electrical machinery and apparatus manufacturing Energy-saving equipment/Automatic instrument manufacturing Carrier machine manufacturing Packaging machinery manufacturing Hydraulic pressure equipment manufacturing Food industry machinery manufacturing Industrial robot manufacturing |
Product manufacturing | Plant equipment manufacturing | Plant equipment manufacturing Marine vessel equipment manufacturing Steel and furnace apparatus manufacturing Hydro/thermal/electric/atomic power generation apparatus manufacturing Large-size plant apparatus manufacturing |
Product manufacturing | Construction and civil engineering machinery manufacturing | Civil engineering machinery manufacturing Construction and civil engineering material manufacturing Interior and outer wall material manufacturing Construction machinery manufacturing |
Product manufacturing | Furniture/Interior | Lighting equipment manufacturing Cabinetmaking |
Product manufacturing | Others | Welfare equipment manufacturing Transportation equipment manufacturing Telecommunication equipment manufacturing |
