Most recent update: 2020-09-14
Company name |
株式会社 T.M.D (Thi-emudhi-) |
Website URL | https://www.t-m-d.jp/ |
Street address |
Gifu Japan
[See map] |
Person in charge | - |
Capital | 3,000,000 JPY | Employees | 30 |
Annual sales | Unregister | EMIDAS Member Number | 94670 |
Type of manufacturing | Machine tools / Industrial machinery / Construction material |
Large | Medium | Small |
Designing | Jig and tool designing | General jig designing Welding jig designing Mass production jig designing |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Can manufacturing Precision sheet metal machining Chassis manufacturing Sheet metal protocol manufacturing Bending (over 3.0 m) Angle machining Pipe bending Deburring Coating 3-roll bending 3-roll bending (2 m or longer) Bending (hydraulic) 3D pipe machining Can manufacturing (over 5 m) |
Development and production of prototype/Small-scale production | Blank cutting | Shearing Cutting Laser and turret punch press processing Laser processing (longer than 121.2 m) Corner shearing CO2 laser machining Laser marking Nitrogen cutting Thin plate (below 6 mm) Thick plate (over 6 mm) Stainless steel Precision cutting 3D laser machining |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Arc welding Stud welding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Welding jig manufacturing Mass production jig manufacturing Jig and tool manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Welding Bending Small-size prototype manufacturing Chassis prototype manufacturing |
Mass production | Metal press | Bending |
Mass production | Sheet-metal processing | Pipe processing Can-making Precision sheet metal processing Housing manufacturing Sheet metal prototype manufacturing Bender processing (over 3.0m) Angle processing Pipe bender processing Deburring process Painting process 3-roll machine 3D pipe processing Can making (more than 5m) Bending process |
Surface treatment | Plating/Chemical conversion treatment | Chromate (general) Gold/Silver plating Alumite (anode oxidation) Acid pickling Trivalent Chromate (barrel plating) Iron Black oxide finish Colored alumite Hot-dip galvanizing (mid-size Hot-dip galvanizing (large-size Unichromate (white) Black chromate (black/green) Colored chromate (multi-color) |
Surface treatment | Coating | Powder coating Electrodeposition coating Melamine coating Epoxy coating Heat insulation coating Metal coating |
Assembly/Inspection | Assembly | Office equipment assembly Construction component assembly Industrial machinery assembly |
Product manufacturing | Construction and civil engineering machinery manufacturing | Construction and civil engineering material manufacturing |
Product manufacturing | Household commodity | Outdoor leisure product manufacturing |
Product manufacturing | Furniture/Interior | Nameplates Interior manufacturing |
