Measuring equipment and testing machine
Honeywell Granit 1911i
Wireless Industrial-Grade Area-Imaging
The Granit™ 1911i wireless industrial-grade area-imaging scanner is designed to withstand the varied demands that exist in harsh working environments. Featuring a custom built housing that is redefining the standard for scanner reliability, the IP65 rated Granit 1911i is built to survive 5,000 3.3´ (1 m) tumbles and 50 drops to concrete from 6.5´ (2 m) even at -4°F (-20°C). As a result, businesses can expect to experience minimal device downtime and a lower overall cost of ownership.
Powered by Honeywell’s Adaptus™ 6.0 imaging technology and its revolutionary decoding architecture, the Granit 1911i provides users with the same exceptional bar code reading performance as the bestin-class Xenon™ series of area-imaging scanners. From poorly printed and damaged codes to low density linear codes, the Granit 1911i is built to read virtually all bar codes with ease—supporting maximum operator productivity with its enhanced illumination, crisp laser aiming and extended depth-of-field.
The Granit 1911i also incorporates a Bluetooth® Class 1, v2.1 radio, enabling wireless connectivity and unrestricted movement up to 300 feet (100 m) from the base. Additionally, with Honeywell’s Shift-PLUS power management system users can expect up to 14 hours of battery life reducing the cost associated with battery backups and replacements. A paging system is also available for added convenience to assist with locating misplaced scanners.
Created specifically for applications in which high performance scanning is expected and durability is highly valued, the Granit 1911i is the optimal solution for businesses operating in unpredictable conditions.
Features
• Class-Leading Durability: The custom-built IP65-rated housing is able to withstand 5,000 3.3´ (1 m) tumbles and survive 50 drops from 6.5´ (2 m) at -4°F (-20°C) reducing service costs and increasing device uptime
• Wireless Connectivity: Bluetooth® Class 1, v2.1 radio enables movement up to 300´ (100 m) from base, and reduces interference with other wireless systems. Up to 7 imagers can communicate with a single base, reducing the total cost of ownership
• TotalFreedom™ 2.0: The second-generation of Honeywell’s area-imaging development platform enables the loading and linking of multiple applications to enhance image decoding, data formatting and image processing—eliminating the need for host system modifications
• Long-Lasting Lithium-Ion Battery: Powers up to 50,000 scans per full charge and is removable without tools ensuring maximum uptime for operations running multiple shifts
• Extended Linear Depth of Field: Scans out-of-reach items with ease and allows users to scan 20 mil linear codes out to 29.5˝ (75 cm) without sacrificing performance on 2D codes
• Remote MasterMind™ Scanning Management Software: Quick and convenient solution for IT administrators seeking to manage the scanners within their network from a single remote location
Company name | NCR GROUP | EMIDAS Member Number | 94450 |
Country | Kingdom of Thailand | Street address |
Bangkok Bangkok Kingdom of Thailand |
Telephone number | +-2-910-8590-5 | Fax number | +-2-586-9075 |
Employees | 20,000,000 THB | Annual sales | |
Employees | 70 | Person in charge | อิสริยาภรณ์ ชุณหเพสย์ |
Type of manufacturing | Measuring machinery / Industrial machinery / Transportation equipment | ||
Primary clients |
