PR message
We are developing a wide range of businesses from automobiles, agricultural equipment, construction machinery to electrical parts.With high accuracy, you can choose your favorite material from aluminum GDC casting to cast iron, FC, FCD and high silicon FCD.
We are engaged in production activities with management based on the strict quality control standard IATF16949.
If you have any questions or requests, please feel free to contact us!
Our Mass production parts example
1) Automotive turbine housing
2) Automotive engine bracket, clutch cylinder
3) Engine parts for agricultural machinery, hydraulic valve body
4) Shave for elevator
5) Water pump body
6) Shaft for air compressor
7) Industrial washing machine main bearings, etc.
We can ship from Thailand to all over the world. Of course, we look forward to receiving requests from customers in Thailand.
We have partners in the NPM Alliance Group in which we joint ventured. We are developing a wide range of businesses from automobiles, agricultural equipment, construction machinery to electrical parts.
NPM Alliance Casting Co., Ltd. mass production parts example
5) Water pump body
Their materials : FC250,FC300,
FCD450,FCD500,FCD550,FCD600,FCD700
FCD Hi Si-Mo
We have partners in the NPM Alliance Group in which we joint ventured. We are developing a wide range of businesses from automobiles, agricultural equipment, construction machinery to electrical parts. We consistently undertake processing to anodize processing with our group companies and business partners. The strength of our aluminum gravity casting is
1) High-pressure resistance (can withstand high hydraulic pressure such as brake fluid and hydraulic fluid)
2) High-quality casting structure (no porosity, shrinkage or other casting defects)
3) High mechanical properties by T6 treatment (heat treatment)
4) Wide range of lot sizes from small quantity to large quantity 100 pcs / M-100,000 pcs / M
5) Material selection possible from various JIS materials (AC2A, AC2B, AC4A, AC4D, etc.)
6) Improvement of strength and wear resistance by anodizing treatment
Widely used in passenger cars, pickups, large trucks, construction machines and excavator.
Company name | Takamatsu NPM(Thailand) Co,Ltd. | Website URL | http://www.npm-alliance.co.th/ |
Street address |
Sriracha Chonburi Kingdom of Thailand
[See map] |
Person in charge | Shinichi Nakashima |
Telephone number | +66-38-110-362 | Fax number | +66-38-110-364 |
Capital | Employees | 51 | |
Annual sales | EMIDAS Member Number | 94441 | |
Type of manufacturing | Transportation equipment / Industrial machinery / Machine tools | ||
Main 3 products |
Primary clients |
Large | Medium | Small |
Designing | Jig and tool designing | General jig designing |
Development and production of prototype/Small-scale production | Machining | General-purpose lathe machining Tapping Deep hole drilling Thread-cutting Straightening Machining/Handles small-scale production (order from 1 piece) Iron Aluminum alloy Copper alloy Molybdenum alloy Broaching Keyway milling Automatic lathe Bench lathe machining Air chuck equipment Casting Handles microfabrication Honing Titanium Brass |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining Boring milling NC vertical lathe Combined lathe machining Machining (horizontal) |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Mass production jig manufacturing Jig and tool manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Small-size prototype manufacturing Aluminum die-casting |
Mass production | Mechanical processing | Machining NC milling machining NC turning machining Tapping machining Complex turning machining Screw cutting machining Spinning Iron Aluminum alloy Automatic screw machining Air chuck equipment Casting Honing machining High precision |
Parts manufacturing | Machinery part | Valve manufacturing Pressure container manufacturing Connection parts manufacturing Crank shaft manufacturing Shaft and roller manufacturing pipe manufacturing Mechanical parts |
Auto parts manufacturing | Drive system part | Clutch Brake parts |
Auto parts manufacturing | Engine | Fuel system |
