PR message
We are developing a wide range of businesses from automobiles, agricultural equipment, construction machinery to electrical parts.
We are engaged in production activities with management based on the strict quality control standard IATF16949.
We can ship from Thailand to all over the world. Of course, we look forward to receiving requests from customers in Thailand.
If you have any questions or requests, please feel free to contact us!
NPM Alliance Casting Co., Ltd. mass production parts example
1) Automotive turbine housing
2) Automotive engine bracket
3) Engine parts for agricultural machinery
4) Shave for elevator
5) Water pump body
6) Shaft for air compressor
7) Industrial washing machine main bearings, etc.
Their materials : FC250,FC300,
FCD450,FCD500,FCD550,FCD600,FCD700
FCD Hi Si-Mo
We have encouraging partners in the NPM Alliance Group in which we joint ventured. We are developing a wide range of businesses from automobiles, agricultural equipment, construction machinery to electrical parts.
With high accuracy, you can choose your favorite material from aluminum GDC casting to cast iron, FC, FCD and high silicon FCD.
Takamatsu NPM (Thailand) Co., Ltd. Mass production parts example
2) Automotive engine bracket, clutch cylinder
3) Engine parts for agricultural machinery, hydraulic valve body
5) Water pump body
We have partners in the NPM Alliance Group in which we joint ventured. We are developing a wide range of businesses from automobiles, agricultural equipment, construction machinery to electrical parts. We consistently undertake processing to anodize processing with our group companies and business partners. The strength of our aluminum gravity casting is
1) High-pressure resistance (can withstand high hydraulic pressure such as brake fluid and hydraulic fluid)
2) High-quality casting structure (no porosity, shrinkage or other casting defects)
3) High mechanical properties by T6 treatment (heat treatment)
4) Wide range of lot sizes from small quantity to large quantity 100 pcs / M-100,000 pcs / M
5) Material selection possible from various JIS materials (AC2A, AC2B, AC4A, AC4D, etc.)
6) Improvement of strength and wear resistance by anodizing treatment
Widely used in passenger cars, pickups, large trucks, construction machines and excavator.
Company name | NPM Allliance Casting Co.,Ltd. | Website URL | http://www.npm-alliance.co.th/ |
Street address |
Sriracha Chonburi Kingdom of Thailand
[See map] |
Person in charge | Daisuke Toyama |
Telephone number | Log in to display | Fax number | Log in to display |
Capital | Employees | 79 | |
Annual sales | EMIDAS Member Number | 94440 | |
Type of manufacturing | Transportation equipment / Industrial machinery / Home electrical appliances | ||
Main 3 products |
Primary clients |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | Iron Casting |
Development and production of prototype/Small-scale production | Casting | Shell mold Gravity casting Sand casting cast iron Ductile cast iron Cast steel 500g-5kg 5kg or more |
Die manufacturing | Casting die | Designing Manufacturing 3D modeling Shell moulding die |
Mass production | Casting | Shell moulding Sand casting Cast-iron Ductile cast iron Over 500 g and less than 5 kg 5 kg and over |
Surface treatment | Other surface treatment | Shot peening/WPC Deburring |
Parts manufacturing | Machinery part | Pressure container manufacturing Connection parts manufacturing Crank shaft manufacturing Ring Mechanical parts |
Auto parts manufacturing | Drive system part | Transmission |
Auto parts manufacturing | Engine | Fuel system |
