Additive for High-Gloss Tin Plating: Improving Solderability and Corrosion Resistance
Product Info
Bright sulfuric acid tin plating additive that provides stable gloss and strong coating across a wide range of current densities. It enhances solder wettability and corrosion resistance, thereby elevating the quality of electrical components and bus bars. In Thailand, it is distributed by DAIWA FINE CHEMICALS (THAILAND) CO., LTD.
This product is an additive for bright sulfuric acid tin plating, forming a consistently high-gloss coating even under varying current densities. In modern electronic component manufacturing, plating is a crucial process that significantly affects reliability and durability, and this additive meets those needs. With low organic absorption in the coating, it offers excellent solder wettability and corrosion resistance, making it ideal for use in fields that demand durability, such as electrical components and bus bars. DAIWA FINE CHEMICALS (THAILAND) CO., LTD. provides this product in Thailand to promptly meet local manufacturing needs.
■ Features
The key features of this bright sulfuric acid tin plating additive are as follows:
- High gloss: Supports a wide range of current densities, providing a uniform and stable high-gloss finish.
- Improved solder wettability: Low organic absorption in the coating enhances solderability and connectivity.
- Excellent corrosion resistance: High corrosion resistance ensures long-term reliability of electrical components.
- Stable coating quality: Forms a strong, durable coating.
■ Specifications
The main specifications of this product are as follows:
- Application: Bright sulfuric acid tin plating process
- Characteristics: Supports a wide range of current densities, forming a uniform high-gloss coating
- Resistance: Low organic absorption in the coating, improving solder wettability and corrosion resistance
- Applicable examples: Bus bars, electronic components, electrical component materials
■ Applications
This additive is effective in the following applications:
- Surface treatment of electronic components: Ideal for electronic components requiring high solderability and connectivity.
- Bus bars and electrical component materials: Suitable for manufacturing electrical components and conductors requiring corrosion resistance.
- Manufacturing processes requiring high-gloss finishes: Stable high-gloss coating enhances the appearance quality of products.
Using this product enables the production of highly reliable and durable electrical components and conductors. DAIWA FINE CHEMICALS (THAILAND) CO., LTD. offers this product to meet the needs of the manufacturing industry in Thailand.
DAIWA FINE CHEMICALS (THAILAND) CO., LTD. is based in Bangkok, Thailand, and provides services all area in Thailand.
■ For more details, please download the PDF or feel free to contact us.
CONTACT
This is the inquiry form for DAIWA FINE CHEMICALS (THAILAND) CO., LTD.. Please enter your inquiry.
This service is intended to provide consultation and opinion requests for processing projects.
Please do not use this information for self-promotion or sales activities.
If we receive a complaint from a recipient about the contents of the transmission, we may take measures such as forcibly stopping the use of the service.
Inquiry Type*Required
Message*Required
Attach file
Only image (jpeg, jpg, gif, png, pdf) and compressed file (zip, lzh) extensions are valid. Maximum file size 10MB
