SERVICE
Corrosion preventive oil for steel and cast iron VERZONE OIL-U
Product Info
VERZONE OIL-U is an anti-corrosion oil that coats the metal surface with an ultra-thin oil film, providing strong anti-corrosion power for both steel and non-ferrous metals. With excellent penetration capability, it reaches even fine gaps and pinholes, ensuring reliable protection. In Thailand, it is distributed by DAIWA FINE CHEMICALS (THAILAND) CO., LTD.
VERZONE OIL-U is an anti-corrosion oil compatible with both steel and non-ferrous metals. Its ultra-thin oil film covers the metal surface uniformly, thoroughly protecting it from corrosion. Thanks to its excellent penetration, it reaches into fine gaps and the depths of pinholes, fully covering the metal surface. This ensures high anti-corrosion performance, even in minute areas prone to corrosion. Combining long-term protective performance and penetration capability, it meets the diverse anti-corrosion needs of metals in Thailand.
■ Features
The main features of VERZONE OIL-U are as follows:
- Excellent penetration: Quickly penetrates the surface of the target metal, covering fine gaps and pinholes thoroughly.
- Ultra-thin oil film formation: Forms a thin and uniform oil film, preserving the original properties and appearance of the metal.
- Suitable for both steel and non-ferrous metals: Provides high anti-corrosion performance not only for steel but also for non-ferrous metals.
- High anti-corrosion power: Protects metal surfaces even in corrosive environments, maintaining anti-corrosion effectiveness over the long term.
■ Specifications
The main specifications of this product are as follows:
- Product name: VERZONE OIL-U
- Form: Ultra-thin oil film type
- Applicable targets: Steel and non-ferrous metals
- Characteristics: High penetration and anti-corrosion power
■ Applications
VERZONE OIL-U is ideal for the following uses:
- Protection of precision parts: Anti-corrosion for precision equipment and parts with fine gaps
- Storage of steel and non-ferrous metals: Prevents corrosion during long-term storage and transportation
- Protection before assembly: Protects metal surfaces from corrosion before and after assembly or processing
VERZONE OIL-U offers excellent anti-corrosion power and penetration, making it a reliable solution for metal protection needs in Thailand.
DAIWA FINE CHEMICALS (THAILAND) CO., LTD. is based in Bangkok, Thailand, and provides services all area in Thailand.
■ For more details, please download the PDF or feel free to contact us.
CONTACT
