SERVICE
water soluble anti-rust for Aluminum and alloy VERZONE LM-N1
Product Info
Water-soluble anti-corrosion agent with inorganic components that inhibit corrosion of aluminum and aluminum alloys. Protects metal surfaces from high pH machining oils and cleaning agents, providing excellent corrosion resistance. In Thailand, it is sold by DAIWA FINE CHEMICALS (THAILAND) CO., LTD.
This product is a water-soluble anti-corrosion agent formulated with inorganic components specifically for aluminum and aluminum alloys. Corrosion of aluminum can often be a concern in environments using high-pH machining oils and cleaning agents, but adding this product effectively inhibits corrosion. It provides strong protection for metal surfaces, making long-term corrosion prevention easy to achieve, and is applicable across a variety of industries involving aluminum processing. It is distributed by DAIWA FINE CHEMICALS (THAILAND) CO., LTD. in Thailand, ensuring smooth integration into local operations.
■ Features
The main features of this water-soluble anti-corrosion agent are as follows:
- High corrosion inhibition: Effectively inhibits corrosion of aluminum even in high-pH machining oil and cleaning agent environments.
- Inorganic component formulation: Based on inorganic components, ensuring stable anti-corrosion performance.
- Easy addition: High solubility in water makes it easy to add during manufacturing processes.
- Environmentally conscious: Designed for efficient and safe corrosion prevention, with consideration for environmental impact.
■ Specifications
The specifications of this product are as follows:
- Applicable materials: Aluminum and aluminum alloys
- Composition: Inorganic components
- Solubility: Water-soluble
- Recommended environment: High-pH machining oils and cleaning agents
■ Applications
This anti-corrosion agent is effective in the following applications:
- Aluminum processing sites: Corrosion prevention in processes using high-pH machining oils and cleaning agents.
- Parts cleaning processes: Corrosion prevention for aluminum parts after cleaning.
- Anti-corrosion for storage and transport: Reducing corrosion risk during long-term storage and transport of processed aluminum products.
Provided by DAIWA FINE CHEMICALS (THAILAND) CO., LTD. in Thailand, this product protects aluminum from high-pH environments, delivering long-lasting anti-corrosion performance.
DAIWA FINE CHEMICALS (THAILAND) CO., LTD. is based in Bangkok, Thailand, and provides services all area in Thailand.
■ For more details, please download the PDF or feel free to contact us.
CONTACT
