Designing |
Product and part designing |
Measurement/testing device designing
Designing |
Jig and tool designing |
General jig designing
Designing |
Test |
Specimen processing
Development and production of prototype/Small-scale production |
Machining |
General-purpose milling
General-purpose lathe machining
Tapping
Thread-cutting
Machining/Handles small-scale production (order from 1 piece)
Iron
Stainless steel
Aluminum alloy
Copper alloy
Nickel alloy
Molybdenum alloy
Machining (resin)
Sintered metal
Keyway milling
Router machining
Milling (resin)
Lathe machining (resin)
Casting
Brass
NC machining |
Machining (vertical)
Additional-axis machining
NC milling
NC lathe machining
5-face/5-axis machining
Machining (horizontal)
Handles 2.5-dimensional processing
Electrical discharge machine |
Wire electric discharge machining
Micro hole machining
Electric discharge machining
Grinding processing |
NC plane grinding
NC cylindrical grinding
Cylindrical grinding
Jig grinding
Internal grinding
Welding/Adhesive bonding |
CO2 welding
TIG welding (argon welding)
Arc welding
Brazing
Jig manufacturing |
General jig manufacturing
Prototype processing |
Plastic protocol machining
Small-size prototype manufacturing
Fused Deposition Molding (FDM)
Aluminum die-casting
Prototype/Small-lot molding
Mass production |
Mechanical processing |
Machining
NC milling machining
NC turning machining
Wire machining
Electrical discharge machining
Iron
Aluminum alloy
Copper alloy
Nickel alloy
Molybdenum alloy
Turning machining(plastic)
Casting
High precision
Mass production |
NC plane grinding
Plane grinding
Jig grinding
Internal grinding
Surface treatment |
Plating/Chemical conversion treatment |
Black oxide finish
Surface treatment |
Polishing/Lapping |
Lap polishing
Lap mirror polishing
