We inspected and repaired the welding machine.
The fire of the welder was higher than usual and was not concentrated, and when we searched for the cause, the bolt at the outlet of the fire was loose and gas was leaking. Tightening the problem is solved.
Normally, the work is mainly done by manufacturers and specialists.
We can also do it ourselves in Moro Thailand.
The Thai side will respond
Japanese engineer who can speak Thai
Thai engineer fluent in Japanese
We will act on behalf of manufacturers who cannot travel from Japan to Thailand.
Even if we have a service base in Thailand, we will help manufacturers who lack manpower.
Company name | Manufacture Overhaul Rapid and Optimal Co., Ltd. | EMIDAS Member Number | 94274 |
Country | Kingdom of Thailand | Street address |
Nong Bon, Prawet Bangkok Kingdom of Thailand |
Telephone number | +-2-115-8838 | Fax number | +-2-115-8010 |
Type of manufacturing | Industrial machinery / Not selected / Not selected | Employees | 4,000,000 THB |
Annual sales | Employees | 13 | |
Person in charge | MANUFACTURE OVERHAUL RAPID AND OPTIMAL CO., LTD. | Primary clients |
