Robot
Manufacturing facilities
"There are many female staff, and it is dangerous to work hard ..."
"The staff has stopped and I am in trouble due to lack of manpower ..."
Do you have such a problem?
Safe and secure "Made in Japan"
Transport equipment of Toyo Koken K.K.
(upper left)
This is an example of introducing the work of scooping up the underside of the cardboard with a forked claw, pulling out the claw at the desired position, and stacking it on a pallet. It is very effective when the area of the upper surface of the cardboard is small and it is difficult to stick.
(Upper right)
This is an introduction of an example introduced in the work of sticking the upper surface of corrugated cardboard and loading it on a pallet or conveyor.
(under)
This is an introduction of an example introduced in the work of sticking the side surface of corrugated cardboard and loading it on a pallet or conveyor.
Using the principle of leverage, you can control the transported items at your will
You can move it up, down, left, and right.
From receiving raw materials/materials to processing/production processes, storage/delivery operations, etc.
Strong support for hard work at diverse and wide-ranging transfer sites.
Work efficiency is improved because heavy objects can be moved with a light force.
We propose the optimum balancer based on the shape and weight of the transported object (work).
From design and manufacture of dedicated attachments to installation and subsequent
With total support from MORO, from maintenance to improvement!
We will act on behalf of manufacturers who cannot travel from Japan to Thailand.
Japanese engineer who can speak Thai
Thai engineer fluent in Japanese
Even if we have a service base in Thailand, we will help manufacturers who do not have enough manpower.
Company name | Manufacture Overhaul Rapid and Optimal Co., Ltd. | EMIDAS Member Number | 94274 |
Country | Kingdom of Thailand | Street address |
Nong Bon, Prawet Bangkok Kingdom of Thailand |
Telephone number | +-2-115-8838 | Fax number | +-2-115-8010 |
Employees | 4,000,000 THB | Annual sales | |
Employees | 13 | Person in charge | MANUFACTURE OVERHAUL RAPID AND OPTIMAL CO., LTD. |
Type of manufacturing | Industrial machinery |
