「板金加工から塗装まで一貫生産」
山形メタルは、板金加工から塗装まで一貫生産に対応しております。
お客様とのコミュニケーションを大切にし、迅速かつ正確に製品を提供することを心がけています。
Construction and civil engineering material manufacturing( Product manufacturing / Construction and civil engineering machinery manufacturing ) |
Interior and outer wall material manufacturing( Product manufacturing / Construction and civil engineering machinery manufacturing ) |
Metal coating( Surface treatment / Coating ) |
Sheet metal prototype manufacturing( Mass production / Sheet-metal processing ) |
Sheet metal protocol manufacturing( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Chassis prototype manufacturing( Development and production of prototype/Small-scale production / Prototype processing ) |
Housing manufacturing( Mass production / Sheet-metal processing ) |
Company name |
株式会社 山形メタル (Yamagatametaru) |
Website URL | http://www.y-metal.co.jp/ |
Street address |
Yamagata Japan
[See map] |
Person in charge | - |
Capital | 90,000,000 JPY | Employees | 115 |
Annual sales | Unregister | EMIDAS Member Number | 94230 |
Type of manufacturing | Machine tools / Industrial machinery / Construction material |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Thread-cutting Iron Stainless steel Aluminum alloy Router machining |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Can manufacturing Chassis manufacturing Sheet metal protocol manufacturing Bending (over 3.0 m) Angle machining Coating 3-roll bending 3-roll bending (2 m or longer) Bending (hydraulic) |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing Cutting Laser and turret punch press processing Laser processing (longer than 121.2 m) Shearing (longer than 121.2 m) Corner shearing Laser marking Thin plate (below 6 mm) Thick plate (over 6 mm) Stainless steel Copper/Aluminum Fiber laser processing |
Development and production of prototype/Small-scale production | Grinding processing | Plane grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Stud welding Projection welding |
Development and production of prototype/Small-scale production | Prototype processing | Welding Bending Small-size prototype manufacturing Chassis prototype manufacturing |
Development and production of prototype/Small-scale production | Blank cutting | Laser marking Turret punch punching Shirring Cutting process Laser and turret punch punching Laser processing (over 1.2m) Shirring (more than 1.2m) Connor Shah Fiber laser processing Clean cut Thin plate 6 mm or less Thick plate 6 mm or more stainless |
Mass production | Mechanical processing | Machining Tapping machining Iron Stainless Aluminum alloy |
Mass production | Grinding processing | NC plane grinding Plane grinding |
Mass production | Sheet-metal processing | Can-making Housing manufacturing Sheet metal prototype manufacturing Bender processing (over 3.0m) Angle processing Painting process 3-roll machine Bender processing (flood control) Bending process |
Mass production | Blank cutting | Laser marking Turret punch punching Shirring Cutting process Laser and turret punch punching Laser processing (over 1.2m) Shirring (more than 1.2m) Connor Shah Fiber laser processing Clean cut Thin plate 6 mm or less Thick plate 6 mm or more stainless |
Mass production | Welding / welding | Projection welding CO2 welding Spot welding TIG welding (argon welding) Arc welding Stud welding |
Surface treatment | Coating | Air-spray coating Powder coating Resin coating Electrostatic coating Melamine coating Urethane coating Acrylic coating Epoxy coating Heat insulation coating Heat-resistant coating Metal coating Fluorine coating |
Surface treatment | Other surface treatment | Shot blast Etching (surface treatment) |
Product manufacturing | Construction and civil engineering machinery manufacturing | Construction and civil engineering material manufacturing Interior and outer wall material manufacturing |
