Manufacturing facilities
1) Standard diaphragm valve with a weir in the flow path.
2) With built-in diaphragm (membrane) to partition fluids, and the superior sealing structure prevents contamination to fluids.
3) A simple structure with three units: the "actuator," "diaphragm," and "body." The top entry system makes it easy to perform maintenance such as replacement of the diaphragm.
4) The most suitable materials for the body and diaphragm can be chosen to match the fluid composition, for a cost efficience, corrosion and chemically resistance.
5) Choose an actuator that meets your requirements. Applies to manually operated, pneumatically operated, flow controlling, and electrically operated types.
usage
Chemical, environment/water treatment, iron and steel, ship, semiconductor, power including nuclear power, and other sectors.
Company name | Seika Sangyo (Thailand) Co., Ltd. | EMIDAS Member Number | 94170 |
Country | Kingdom of Thailand | Street address |
Patumwan Bangkok Kingdom of Thailand |
Telephone number | +-+66-2-108-9818 | Fax number | +-+66-2-108-9820 |
Employees | 20,000,000 THB | Annual sales | |
Employees | 18 | Person in charge | Mr. Mie |
Type of manufacturing | Heavy electric machinery / Measuring machinery / Industrial machinery |
