PR message
ENDO machined metal with high accuracy, mainly machining of center . Mass production with quality stable product. Currently, ENDO can process a series of SUS303 materials with a tolerance of up to 5μmm.
[Linear guide casing processing machining center Vietnam]
We mass-produce linear guide casings at machining centers.
We have a factory near Hanoi, Vietnam, so we are processing locally in Vietnam.
[Facilities of ENDO VIETNAM]
At our company, we have 40 machining centers, 2 surface grinders, and 1 NC automatic lathe centered on FANUC ROBODRILLs.
From small lots to mass production, we can handle a wide range of needs, so please feel free to contact us if you are having trouble procuring in Vietnam.
<Machining center>
38 FANUC ROBODORILL
Mori Seiki VERTICAL 5060 2 units
<Surface grinder>
Okamoto Machine Tool PSG52DXNC / PSG52CANC 1 each
<NC automatic lathe>
Citizen Machinery L20 1 unit
[Materials supported by ENDO VIETNAM]
Aluminum: A5052, A6063
Stainless steel: SUS303, SUS304, SUS440, SUS316
Carbon steel: S45C, S50C, SS400
[Leave it to us for precision parts processing in Vietnam]
If you need precision parts processing in Vietnam, please leave it to ENDO VIETNAM.
We can handle everything from small lots to mass production.
[Precision aluminum machining center, parts for the semiconductor industry, material: A5052, surface treatment: white alumite, Vietnam]
Precision aluminum processed products for semiconductors.
I am working on a machining center.
<Machining center>
38 FANUC ROBODORILL
<Surface grinder>
[Precision aluminum processing, machining center, epoxy-coated parts, Vietnam]
Precision aluminum processed products for communication equipment.
<Machining center>
38 FANUC ROBODORILL
<Surface grinder>
[Precision aluminum processing, machining center, industrial robot parts, alumite parts, Vietnam]
Precision aluminum processed products for industrial robots.
<Machining center>
38 FANUC ROBODORILL
<Surface grinder>
Production equipment parts for the semiconductor industry
Material: SGD400 Surface treatment: Electroless nickel plating Pin press fit
ENDO Vietnam's main products, linear motion rolling guides, are
It is used in a wide range of fields such as large machine tools and construction machinery.
We can flexibly respond to processing, surface treatment, etc. in cooperation with partner companies.
We handle a wide range of products, mainly aluminum products, as well as iron, stainless steel, and copper processing.
[Precision aluminum processing, machining center, communication equipment, Vietnam]
<Machining center>
38 FANUC ROBODORILL
Mori Seiki VERTICAL 5060 1 unit
<Surface grinder>
Company name | ENDO VIETNAM CO., LTD | Website URL | |
Street address |
Dong Anh Ha Noi Socialist Republic of Vietnam
[See map] |
Person in charge | Makoto Ozeki |
Telephone number | +84-+84-24-3950-0888 | Fax number | +84-+84-24-3950-1999 |
Capital | 370,000 $ | Employees | 260 |
Annual sales | EMIDAS Member Number | 94066 | |
Type of manufacturing | Industrial machinery / Office automation equipment / Telecommunication equipment | ||
Main 3 products |
Large | Medium | Small |
Designing | Jig and tool designing | General jig designing |
Designing | Simulation | Cutting |
Development and production of prototype/Small-scale production | Machining | General-purpose lathe machining Tapping Deep hole drilling Thread-cutting Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel High rigid material Aluminum alloy Copper alloy Sintered metal Automatic lathe Casting Handles microfabrication Handles microfabrication Brass |
Mass production | Mechanical processing | Machining NC turning machining Tapping machining Wire machining Screw cutting machining Micro-hole machining Iron Stainless Cemented carbide Aluminum alloy Copper alloy Sintered metal Automatic screw machining Air chuck equipment Casting Fine particle material accepted High precision |
Parts manufacturing | Machinery part | Valve manufacturing Bearing manufacturing Mechanical parts |
