弊社は様々な板厚や材質に対応できるレーザー加工のほか、長さ4mまで対応可能な曲げ加工、穴あけ加工、タップ加工、皿穴加工、ザグリ加工、溶接、機械加工などのほか、鉄やステンレスの組立溶接や製缶も可能です。
Fiber laser processing( Development and production of prototype/Small-scale production / Blank cutting ) |
Precision sheet metal machining( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
TIG welding (argon welding)( Development and production of prototype/Small-scale production / Welding/Adhesive bonding ) |
Can manufacturing( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Machining (vertical)( Development and production of prototype/Small-scale production / NC machining ) |
Machining (horizontal)( Development and production of prototype/Small-scale production / NC machining ) |
Nitrogen cutting( Development and production of prototype/Small-scale production / Blank cutting ) |
Company name |
大三鋼機 株式会社 (Daisannkouki) |
Website URL | http://www.daisankouki.co.jp/ |
Street address |
Aichi Japan
[See map] |
Person in charge | - |
Capital | 28,000,000 JPY | Employees | 94 |
Annual sales | Unregister | EMIDAS Member Number | 93928 |
Type of manufacturing | Transportation equipment / Industrial machinery / Machine tools |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | Tapping |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling Boring milling Machining (horizontal) |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Can manufacturing Precision sheet metal machining Chassis manufacturing Sheet metal protocol manufacturing Bending (over 3.0 m) Angle machining Deburring Bending (hydraulic) Bending (servo) Thin wall (Thickness |
Development and production of prototype/Small-scale production | Blank cutting | CO2 laser machining Nitrogen cutting Thin plate (below 6 mm) Thick plate (over 6 mm) Stainless steel Copper/Aluminum Fiber laser processing |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding TIG welding (argon welding) Arc welding |
