Most recent update: 2022-06-24
Casting( Designing / Simulation ) |
Company name |
山青精密工業有限会社 (Honnkonnsannseiseimitsukougyou) |
Website URL | |
Street address |
Shandong People's Republic of China
[See map] |
Person in charge | - |
Capital | 1,000,000,000 JPY | Employees | 50 |
Annual sales | 1,000,000,000 JPY | EMIDAS Member Number | 93905 |
Type of manufacturing | Jigs and tools / Industrial machinery / Measuring machinery |
Large | Medium | Small |
Designing | Mold designing | Forging die designing Casting die designing |
Designing | Jig and tool designing | General-purpose jig designing |
Designing | Industrial equipment designing | Energy-saving machinery designing |
Designing | Simulation | Casting |
Material | Steel component distribution | Stainless steel Tool steel Free-machining steel Steel (round) bar |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Rolling Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Aluminum alloy Copper alloy Titanium alloy Machining (resin) Keyway milling Milling (resin) Lathe machining (resin) Casting Urethane Brass |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining Combined lathe machining Machining (horizontal) Handles 2.5-dimensional processing |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining Micro hole machining Electric discharge machining |
Development and production of prototype/Small-scale production | Grinding processing | Plane grinding Form grinding Cylindrical grinding Jig grinding Cylindrical mirror grinding Internal grinding Centerless grinding Double-sided grinding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Welding jig manufacturing Mass production jig manufacturing Jig and tool manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Welding Plaster casting prototype Aluminum die-casting Small-lot/Injection molding prototype mold |
Development and production of prototype/Small-scale production | Casting | die-cast Gypsum casting Shell mold Lost wax Low pressure casting Gravity casting Centrifugal casting Sand casting Metal injection molding (MIM) cast iron Ductile cast iron Cast steel Aluminum alloy Copper alloy Zinc alloy Magnesium alloy Aluminum bronze 500g-5kg |
Die manufacturing | Press die | Part processing |
Die manufacturing | Plastic mold | Part processing |
Mass production | Mechanical processing | Machining NC milling machining NC turning machining Complex turning machining Wire machining Micro-hole machining Electrical discharge machining Iron Stainless Aluminum alloy Copper alloy Titanium alloy Automatic screw machining Turning machining(plastic) High precision |
Mass production | Casting | Lost-wax Sand casting Cast-iron Ductile cast iron Cast steel Aluminum alloy Copper alloy Zinc alloy Magnesium alloy Over 500 g and less than 5 kg Metal injection molding (MIM) Aluminum bronze alloy Plaster casting |
Mass production | Grinding processing | Plane grinding Form grinding Cylindrical grinding Jig grinding Cylindrical mirror grinding Internal grinding Double-sided grinding |
Surface treatment | Plating/Chemical conversion treatment | Nickel (barrel) Chromium (barrel) Chromate (general) Nickel (rack) Chromium (rack) Alumite (anode oxidation) Nickel chromium (rack) Acid pickling Electroless nickel (barrel) Iron Copper Brass Aluminum Stainless steel Hard chromium (rack) Titanium Degreasing Black oxide finish Colored alumite Hard alumite Unichromate (white) Hard chrome (barrel) |
Surface treatment | Polishing/Lapping | Electropolishing Tool polishing Buffing Mirror polishing |
Surface treatment | Printing and others | NC engraving Engraving Laser engraving |
Surface treatment | Heat treatment | Normalizing Vacuum normalizing Annealing Full annealing Stress relief annealing (SR treatment) Straightening annealing Vacuum annealing Quenching Air quenching Salt bath quenching Vacuum quenching High frequency quenching Flame quenching Carburized quenching Salt bath soft nitriding (tufftriding) Nitridation |
Assembly/Inspection | Assembly | Precision equipment assembly Industrial machinery assembly |
Parts manufacturing | Machinery part | Mechanical parts |
Auto parts manufacturing | Body part | Other body parts |
Product manufacturing | Production property | Machine tool manufacturing Energy-saving equipment/Automatic instrument manufacturing Carrier machine manufacturing Packaging machinery manufacturing Measurement/testing devices manufacturing Hydraulic pressure equipment manufacturing Food industry machinery manufacturing Chemical industry machinery and equipment manufacturing |
