Automobile (mass production)
Railway
Shipbuilding
BAKES is high performance phenol resin for various industry. Greats function such as
higher heat resistant and better wear resistant at the same time for machinery , mechanical press clutch and brake, etc.
Other great function such as for water or waterless application. Sometimes usual
bearing can't perform under lack of lubrication or water condition. BAKES bearing is
a choice for such application. Example is steel industry , Under water lube condition and
high temp condition , BAKES material can perform under two extreme condition and plus
benefit from lower wear which lead to better shaft condition.
Company name | THAI STARLITE MANUFACTURING CO., LTD. | EMIDAS Member Number | 93618 |
Country | Kingdom of Thailand | Street address |
TAMBOL WANGTAKIEN, AMPHUR MUANG CHACHOENGSAO Chachoengsao Kingdom of Thailand |
Telephone number | +-33-599-571 | Fax number | +-33-599-583 |
Employees | 84,000,000 THB | Annual sales | |
Employees | 398 | Person in charge | Apichart Panitchayarom |
Type of manufacturing | Office automation equipment |
