PR message
Strength:
We follow the production and management model of the Japanese factory.
For more than 20 years, Kangda has maintained good relationships with customers in Japan, Europe and the United States.
Production is capable to run 24 hrs 7 days a week.
We can give you an urgent quotation within 12 hours.
Highly capable ERP system called IFS, is used for MRP, Quality control.
Part Number: KD-C021
Part Name: Aluminum non-standard fixtures
Raw Material: Al2017
Surface Treatment: None
Dimension: Customized
Application: Automation
Tolerance: 0.008mm
Packing Information: Neutral packing, special packing as per customer’s request
Delivery time: 10 days for samples, 25 days for mass production
Processing Machines: Milling machine, CNC machining center, wire cutting
Our factory has more than 20 years experience in exporting metal products to Japan, Europe and America. If you are interested in our products, please do not hesitate to contact us.
Part Number: KD-C007
Part Name: Aluminum parts for equipment
Raw Material: Al6061
Surface Treatment: Anodizing
Tolerance: 0.005mm
Packing Information: Neutral packing, special packing as per customer's request
Delivery Time: 10 days for sample, 25 days for mass production
Processing Machines: Milling machine, wire cutting, CNC machining center
Part Number: KD-C019
Part Name: High frequency quenching parts
Raw Material: S45C
Surface Treatment: High frequency quenching
Application: Medical
Tolerance: 0.02mm
Part Number: KD-C020
Part Name: Motor assembly
Raw Material: S45C
Surface Treatment: Heat Treatment
Tolerance: 0.01mm
Processing Machines: Turning machine, CNC machining center, wire cutting
Note:
We specialize in CNC machining of customers' drawings or samples.
Advanced equipment, excellent R&D team and strict quality control system.
These parts are manufactured by high precision CNC machine tools. All sizes are made to meet customer requirements.
High-precision parts are inspected 100% before shipment.
The payment method we accept is FOB or CIF. Sample orders are acceptable.
Hand soldering is the basis of tin-lead soldering technology. Although modern enterprises have generally used the production process of automatic insertion and automatic welding, the products are trial-produced, small-volume production, and high-reliability products with special requirements are also used for manual welding.
Part Number: KD-C016
Part Name: Welding parts with fine appearance
Raw Material: S45C
Application: Automotive
Tolerance: 0.02mm
Part Number: KD-C002
Part Name: CNC machining parts with precision hole
Raw Material: Carbon steel
Tolerance: 0.003mm
Processing Machines: Milling machines, CNC machining centers, grinding machines
Machining (vertical)( Development and production of prototype/Small-scale production / NC machining ) |
Company name | Kangda Precision Manufacturing Co., Ltd | Website URL | https://www.kangdacnc.com/ |
Street address |
Shenzhen Guangdong People's Republic of China
[See map] |
Person in charge | Ryan Lee |
Telephone number | 755-27258813 | Fax number | Log in to display |
Capital | 5,000,000 RMB | Employees | 120 |
Annual sales | 7,000,000 $ | EMIDAS Member Number | 93576 |
Type of manufacturing | Electrical component for transportation equipment / Electronic parts / Heavy electric machinery | ||
Main 3 products |
Primary clients |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | Melt cutting General-purpose milling General-purpose lathe machining Tapping Planer machining Plano miller machining Deep hole drilling Gear hobber Rolling Thread-cutting Profile milling Straightening Tube drawing Spinning Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel High rigid material Aluminum alloy Copper alloy Magnesium alloy Titanium alloy Nickel alloy Molybdenum alloy Ceramic Machining (resin) Sintered metal Sintered metal Broaching Keyway milling Automatic lathe Bench lathe machining Shaper machining Router machining Simultaneous 5-axis machining Milling (resin) Air chuck equipment Lathe machining (resin) Casting Handles microfabrication Handles microfabrication Honing Titanium pipe manufacturing Urethane Sponge Brass Diamond |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) Additional-axis machining NC milling NC lathe machining 5-face/5-axis machining Five-face machining Boring milling NC facing NC vertical lathe Combined lathe machining Machining (horizontal) Handles 2.5-dimensional processing Handles 3D processing |
Development and production of prototype/Small-scale production | Grinding processing | NC plane grinding NC cylindrical grinding Plane grinding Form grinding Cylindrical grinding Profile grinding Jig boring Jig grinding Cylindrical mirror grinding Internal grinding Centerless grinding Thread grinding Gear grinding NC internal grinding Magnetic Abrasive |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding Plasma welding Seam welding Arc welding Submerged arc welding Hot plate welding High-frequency welding Infrared welding |
Die manufacturing | Press die | Manufacturing Part processing Compound die |
Mass production | Mechanical processing | Machining NC milling machining NC turning machining Tapping machining Five-face/axes machining Complex turning machining Wire machining Gear cutting machining Rolling machining Screw cutting machining Micro-hole machining Electrical discharge machining Spinning Iron Stainless Cemented carbide Aluminum alloy Copper alloy Magnesium alloy Titanium alloy Nickel alloy Molybdenum alloy Ceramic Sintered metal Broaching machining Automatic screw machining Air chuck equipment Turning machining(plastic) Casting Honing machining Titanium Fine particle material accepted Urethane Sponge Diamond Seamless Ultra-thin High precision Clad |
Parts manufacturing | Machinery part | Gear manufacturing Valve manufacturing Bearing manufacturing Vacuum components manufacturing Pressure container manufacturing Connection parts manufacturing Magnet containing products manufacturing Crank shaft manufacturing Optical parts manufacturing Shaft and roller manufacturing Measurement devices manufacturing pipe manufacturing Ring |
Parts manufacturing | Other parts | Model manufacturing Lock manufacturing Filter manufacturing Metallic mesh manufacturing |
