Most recent update: 2023-10-10
Machining (vertical)( Development and production of prototype/Small-scale production / NC machining ) |
Company name |
一般社団法人 ヤマトプロジェクト (Yamatopurojekuto) |
Website URL | http://yamato-project.com/ |
Street address |
Hiroshima Japan
[See map] |
Person in charge | - |
Capital | Unregister | Employees | 500 |
Annual sales | Unregister | EMIDAS Member Number | 93575 |
Large | Medium | Small |
Designing | Product and part designing | Gear designing Medical equipment designing External design |
Designing | Jig and tool designing | General jig designing Mass production jig designing |
Designing | Industrial equipment designing | Plant equipment designing Industrial machinery designing |
Designing | Simulation | 3D modeling Press Resin Structure |
Development and production of prototype/Small-scale production | Machining | Melt cutting General-purpose milling General-purpose lathe machining Tapping Deep hole drilling Gear hobber Thread-cutting Profile milling Straightening Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel High rigid material Aluminum alloy Copper alloy Titanium alloy Ceramic Sintered metal Keyway milling Automatic lathe Simultaneous 5-axis machining Casting Handles microfabrication Titanium Brass |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining 5-face/5-axis machining Combined lathe machining Machining (horizontal) |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining Micro hole machining Electric discharge machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Deburring Coating Mirror surface machining Thin wall (Thickness |
Development and production of prototype/Small-scale production | Blank cutting | YAG laser machining Water jet cutter machining Thin plate (below 6 mm) Thick plate (over 6 mm) Stainless steel Copper/Aluminum |
Development and production of prototype/Small-scale production | Grinding processing | NC plane grinding Gear grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | Spot welding TIG welding (argon welding) Arc welding Robot welding YAG laser machining Hot plate welding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Mass production jig manufacturing Jig and tool manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Plastic protocol machining Welding Bending Small-size prototype manufacturing Chassis prototype manufacturing Model manufacturing Aluminum die-casting Prototype/Small-lot molding Small-lot/Injection molding Simplified/Molding prototype mold |
Development and production of prototype/Small-scale production | Casting | cast iron Ductile cast iron Cast steel Aluminum alloy Copper alloy 500g-5kg |
Die manufacturing | Press die | Designing 3D modeling Progressive die Press robot die 60 - 300 t |
Mass production | Mechanical processing | Machining NC milling machining NC turning machining Tapping machining Five-face/axes machining Complex turning machining Wire machining Gear cutting machining Micro-hole machining Electrical discharge machining Iron Stainless Cemented carbide Aluminum alloy Copper alloy Magnesium alloy Titanium alloy Nickel alloy Ceramic Sintered metal Automatic screw machining Casting Titanium Fine particle material accepted Ultra-thin High precision |
Mass production | Plastic | Insert molding Outsert molding General-purpose material PMMA (polymethyl methacrylate) Engineering plastic Urethane resin PU (polyurethane) Elastomer Below 60 t 60 - 300 t 000 t Injection molding Handles small-scale production Thin wall molding Dual molding general purpose plating Decorative Painting |
Mass production | Casting | Sand casting Cast-iron Ductile cast iron Cast steel Aluminum alloy Copper alloy Zinc alloy Magnesium alloy Over 500 g and less than 5 kg |
Mass production | Sheet-metal processing | Bender processing (servo) Bending process |
Mass production | Welding / welding | Spot welding TIG welding (argon welding) Arc welding Robot welding YAG laser processing Semiconductor laser welding |
Surface treatment | Plating/Chemical conversion treatment | Iron Hot-dip galvanizing (mid-size Hot-dip galvanizing (large-size |
Surface treatment | Coating | Melamine coating Urethane coating Acrylic coating Fluorine coating |
Assembly/Inspection | Assembly | Industrial machinery assembly |
Assembly/Inspection | Repair | Industrial machinery repair |
Parts manufacturing | Machinery part | Gear manufacturing |
Parts manufacturing | Spring | Compression coil spring Tensil coil spring Leaf spring Shaped spring Formed wire spring Torsion spring Piano wire (carbon wire) Stainless steel Diameter Diameter |
Product manufacturing | Production property | Machine tool manufacturing Other industrial machinery manufacturing |
Product manufacturing | Plant equipment manufacturing | Plant equipment manufacturing |
