Company name | C.C.S. ENGINEERING CO., LTD. | Website URL | http://www.ccsgroups.com |
Street address |
Bangyai Nonthaburi Kingdom of Thailand
[See map] |
Person in charge | MAMORU ICHIHAZAMA |
Telephone number | +66-89-813-9076 | Fax number | Log in to display |
Capital | Employees | 1000 | |
Annual sales | EMIDAS Member Number | 93521 | |
Type of manufacturing | Electronic parts / Transportation equipment / Construction material | ||
Main 3 products |
PR message
At CCS, we are a vertically integrated "One Stop Manufacturing Company" involved in CNC turning/machining, metal stamping, plastic molding, mold/die, jigs/fixtures and cutting tools manufacturing. Our production system includes "One-Off", "Small Batch" as well as "Mass Production" high quality precision parts.
Most recent update:2021-12-14
Large | Medium | Small |
Designing | Mold designing | Injection molding die Progressive die designing (light electrical) Progressive die designing (auto) Drawing metal press die designing General metal press die |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Deep hole drilling Thread-cutting Straightening Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel High rigid material Aluminum alloy Copper alloy Titanium alloy Machining (resin) Keyway milling Router machining Simultaneous 5-axis machining Milling (resin) Lathe machining (resin) Casting Handles microfabrication Handles microfabrication Honing Titanium Urethane Brass |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) Additional-axis machining NC milling NC lathe machining 5-face/5-axis machining Five-face machining Boring milling NC facing NC vertical lathe Combined lathe machining Machining (horizontal) Handles 2.5-dimensional processing Handles 3D processing |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining Micro hole machining Electric discharge machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Can manufacturing NC set press Chassis manufacturing Sheet metal protocol manufacturing Pipe bending Deburring Mirror surface machining Bending (hydraulic) Bending (servo) Can manufacturing (over 5 m) Thin wall (Thickness |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing Laser and turret punch press processing Shearing (longer than 121.2 m) Water jet cutter machining Laser marking Etching Thin plate (below 6 mm) Stainless steel |
Development and production of prototype/Small-scale production | Grinding processing | NC plane grinding NC cylindrical grinding Form grinding Jig boring Jig grinding Internal grinding Centerless grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Arc welding Brazing |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Welding jig manufacturing Mass production jig manufacturing Jig and tool manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Punching Welding Bending Small-size prototype manufacturing Prototype/Small-lot molding Small-lot/Injection molding |
Die manufacturing | Press die | Designing Manufacturing Part processing Plate machining Die set machining NC data creation Drawing die Blanking die Progressive die Transfer press die Single press die Below 60 t 60 - 300 t |
Die manufacturing | Plastic mold | Designing Manufacturing Part processing Plate machining Mold base machining NC data creation Injection molding die Vacuum/Air pressure molding die 60 - 300 t |
Die manufacturing | Rubber mold | Designing Rubber mold part processing and other auto parts Light electrical/earthing rubber |
Mass production | Metal press | Iron Stainless steel Aluminum Copper Single press (below 80 t) Single press (80 - 200 t) Progressive press (35 - 80 t) Progressive press (80 - 200 t) |
Mass production | Mechanical processing | Machining NC turning machining Tapping machining Five-face/axes machining Complex turning machining Iron Stainless Aluminum alloy Copper alloy Titanium alloy Nickel alloy Sintered metal Automatic screw machining Turning machining(plastic) Fine particle material accepted High precision |
Mass production | Plastic | General-purpose material 60 - 300 t Injection molding |
Surface treatment | Plating/Chemical conversion treatment | Chromium (rack) Electroless nickel (rack) Hard chromium (rack) |
Surface treatment | Coating | Air-spray coating |
Surface treatment | Polishing/Lapping | Tool polishing Blade polishing |
Surface treatment | Lap polishing | Lap polishing Lap mirror polishing |
Surface treatment | Barrel polishing | Barrel finishing (rotation) |
Surface treatment | Other surface treatment | Sound blast |
Assembly/Inspection | Assembly | Precision equipment assembly Industrial machinery assembly |
Parts manufacturing | Machinery part | Mechanical parts |
Product manufacturing | Production property | Other industrial machinery manufacturing Electrical machinery and apparatus manufacturing Energy-saving equipment/Automatic instrument manufacturing Measurement/testing devices manufacturing |
