Most recent update: 2023-09-30
Progressive press (200 - 500 t)( Mass production / Metal press ) |
Company name |
株式会社 岡村鉄工所 (Okamuratekkoujo) |
Website URL | http://www.okamura-iw.co.jp |
Street address |
Hiroshima Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 41 |
Annual sales | Unregister | EMIDAS Member Number | 93430 |
Type of manufacturing | Jigs and tools / Transportation equipment / Medical equipment |
Large | Medium | Small |
Designing | Mold designing | Progressive die designing (auto) Drawing metal press die designing General metal press die |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC lathe machining 5-face/5-axis machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | NC set press Precision sheet metal machining Chassis manufacturing Sheet metal protocol manufacturing Deburring Coating 3-roll bending Bending (hydraulic) |
Development and production of prototype/Small-scale production | Grinding processing | Plane grinding Rotary grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding TIG welding (argon welding) Robot welding Projection welding |
Development and production of prototype/Small-scale production | Jig manufacturing | Welding jig manufacturing Mass production jig manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Welding Bending Chassis prototype manufacturing Prototype/Small-lot molding prototype mold |
Die manufacturing | Press die | Designing Manufacturing Part processing Die set machining Drawing die Bending die Blanking die Forming die Shaving die Progressive die Single press die 60 - 300 t Compound die |
Mass production | Metal press | Drawing Bending Blanking Forming Shaving Coining Iron Stainless steel Aluminum Copper Brass Plated steel plate Thickness Thickness Thickness Thickness printing plating Painting Degreasing welding Tap processing crimp Single press (below 80 t) barrel Single press (80 - 200 t) Single press (200 - 500 t) Progressive press (35 - 80 t) Progressive press (80 - 200 t) Progressive press (200 - 500 t) Progressive press (over 500 t) |
Mass production | Mechanical processing | Machining NC turning machining Tapping machining Complex turning machining Wire machining |
Mass production | Grinding processing | Rotary grinding |
Mass production | Sheet-metal processing | NC set press Housing manufacturing Sheet metal prototype manufacturing Deburring process Painting process 3-roll machine Bending process |
Mass production | Welding / welding | Projection welding CO2 welding Spot welding TIG welding (argon welding) Robot welding |
Surface treatment | Cleaning | Shower-type cleaning Ultrasonic cleaning |
Surface treatment | Barrel polishing | Barrel finishing (vibration) Barrel finishing (rotation) |
Assembly/Inspection | Assembly | Precision equipment assembly Auto parts assembly Construction component assembly Industrial machinery assembly |
Auto parts manufacturing | Interior part | Seat parts Communication accessories Audio components |
