Most recent update: 2023-10-02
Company name |
株式会社 久保田鐵工所 (Kubotatekkoujo) |
Website URL | http://www.kubota-iron-works.com |
Street address |
Hiroshima Japan
[See map] |
Person in charge | - |
Capital | 30,000,000 JPY | Employees | 368 |
Annual sales | 9,850,000,000 JPY | EMIDAS Member Number | 93330 |
Type of manufacturing | Transportation equipment |
Large | Medium | Small |
Designing | Simulation | 3D modeling CAE fluid analysis Thermal analysis Fluid Fluid-fluid heat Fluid and acoustic Structure Gas |
Designing | Data creation (3D scan) | Data creation (3D scan) |
Mass production | Mechanical processing | Machining NC milling machining NC turning machining Tapping machining Complex turning machining Gear cutting machining Rolling machining Screw cutting machining Spinning Iron Aluminum alloy Sintered metal Broaching machining Automatic screw machining Casting High precision |
Mass production | Plastic | Insert molding Engineering plastic PPS (polyphenylene sulfide) GFRP (glass fiber reinforced plastic) 60 - 300 t Injection molding Handles small-scale production Thin wall molding Dual molding |
Mass production | Grinding processing | NC cylindrical grinding Cylindrical grinding |
Surface treatment | Heat treatment | High frequency quenching |
Assembly/Inspection | Assembly | Auto parts assembly |
Assembly/Inspection | Inspection | Plastic |
Parts manufacturing | Machinery part | Gear manufacturing Mechanical parts |
Auto parts manufacturing | Drive system part | Clutch Transmission Drive shaft |
Auto parts manufacturing | Engine | Cooling system |
