Most recent update: 2024-02-29
愛知県春日井市においてエレベータの構造部品・工作機械の架台、駆動部品など強度と精度を要する重厚長大の製品を板金から溶接、機械加工、塗装、組み立てまで自社内で一括加工を行うことを特徴としています。
5-face/5-axis machining( Development and production of prototype/Small-scale production / NC machining ) |
Company name |
株式会社 丸菱製作所 (Marubishiseisakusho) |
Website URL | http://www.marubishi-co-ltd.com |
Street address |
Aichi Japan
[See map] |
Person in charge | - |
Capital | 36,000,000 JPY | Employees | 90 |
Annual sales | 1,700,000,000 JPY | EMIDAS Member Number | 92811 |
Type of manufacturing | Machine tools / Transportation equipment |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | Melt cutting Plano miller machining Thread-cutting |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling 5-face/5-axis machining Five-face machining Boring milling Machining (horizontal) |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Can manufacturing Bending (over 3.0 m) Angle machining Pipe bending Coating Hair line machining 3-roll bending 3-roll bending (2 m or longer) Bending (hydraulic) 3D pipe machining Can manufacturing (over 5 m) |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing Cutting Thin plate (below 6 mm) Thick plate (over 6 mm) 3D laser machining |
Development and production of prototype/Small-scale production | Prototype processing | Welding Bending |
Mass production | Metal press | Bending Blanking Iron |
Mass production | Mechanical processing | Machining NC milling machining Tapping machining Five-face/axes machining Iron Stainless Aluminum alloy |
Mass production | Sheet-metal processing | Pipe processing Can-making Bender processing (over 3.0m) Angle processing Pipe bender processing Painting process Hairline processing Bender processing (flood control) Bender processing (servo) 3D pipe processing Can making (more than 5m) Bending process |
Mass production | Blank cutting | Turret punch punching Shirring Cutting process Connor Shah Thick plate 6 mm or more 3D laser |
Mass production | Welding / welding | CO2 welding TIG welding (argon welding) Arc welding Robot welding |
Surface treatment | Coating | Airless spray coating Urethane coating Lacquer coating Metal coating |
